loads of codes someone help me find problem?
Soo i got a bunch of codes being thrown. The car seems fine but i mean i guess the computer says otherwise? Let me upload pic real quick. Here you go anyone able to help me find out what the actual problem is instead of guessing
sorry sir thanks for changing title.
James- im not doubting you I was just like what does he mean diagnose. Not sure if you figured out by now or not but my knowledge of cars is very limited. Besides turning on hpt and pressing scan, which you even had to show me how to do, I dont know how to diagnose anything. I wouldn't be able to tell if something is bad just by looking at it and don't have voltmeters and other tools to check if somethings bad so was trying to find alternatives on here.
Ok, you installed a Lsj t.b onto the car which is a different pinned throttle body nd etc then the 2.4. So you had to cut and splice. If you didn't solder that will be your key issue... Now the codes that are thrown all pinpoint your issue at the t.b.... So checking working and etc is the start. Resolder, heat shrink,
And recheck. If nogo, check voltages and resistance within the wiring. If you find no issue check the t.b for resistant spots within the potentiometer part of the t.b and check your gas pedal tps sensor (potentiometer) For the same thing
Asking questions are fine and getting other opinions are fine. But I'm not gonna lead you in a incorrect path...
Last edited by Chevycobaltss3; 06-26-2012 at 12:16 AM. Reason: Automerged Doublepost
