lookie lookie
Old Nov 4, 2007 | 05:40 PM
Fast Freddy's Avatar
lookie lookie
Misfiring at high rpm. This was the problem.
Just ordered Diamond pistons, pins and rings. I will be installing them this week, Ill keep you all posted.
Old Nov 4, 2007 | 05:45 PM
07SSCharged248's Avatar
ouch....
Old Nov 4, 2007 | 06:20 PM
davidd05's Avatar
oooh. not good
Old Nov 4, 2007 | 06:30 PM
WSFrazier's Avatar
How do the sleeves look? If you can still use the same sleeves, should be an easy fix.
Pop the new ones in and start her up. Don't forget conventional oil
Old Nov 4, 2007 | 06:34 PM
Red2.4SS's Avatar
Shitty! But it will be even stronger now!
Old Nov 4, 2007 | 06:36 PM
ItalianJoe1's Avatar
All it was doing was missing at high RPMs?
G85 SS's Avatar
Yikes...another victim to overboosting? And was it number 4?
Old Nov 4, 2007 | 06:37 PM
EAKE 714's Avatar
Ouch!
Old Nov 4, 2007 | 06:41 PM
WSFrazier's Avatar
That is caused by heat, not boost.
Old Nov 4, 2007 | 06:44 PM
SSdan's Avatar
What are your mods?
What exactly were your symptoms and what made you 'tear' it down?
Old Nov 4, 2007 | 06:51 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
That looks interesting but I have a bigger question, what the hell is going on Freddy?
You actually make a thread that doesn't link to ****??
What is the world coming to????
Old Nov 4, 2007 | 06:55 PM
R&C_rallySS's Avatar
I would also like to know what cuased this problem. Mainly would like to know what mods you had Freddie
Old Nov 4, 2007 | 07:36 PM
RollOver360's Avatar
yumm... KFC...
Old Nov 4, 2007 | 10:11 PM
The #1 piston is the one I COOKED. When I first purchased my car I just added a smaller pulley nothing more, 3.0 to be exact. A couple of months later I added the original stage 3 kit by Intense racing. 2.8 pulley, maf translator, 42.5 lb injectors and a gutted cat. I was running 4% lean for more horsepower. Dyno'd at 267hp and 249lbs of tq( I believe that is where it all began). 29k mi and a year later I started feeling a sputter at high rpm ittermittently and the sound of my exhaust was different. It was driving me nuckin futs. SO... I thought Fk it -- I went to 60 lb injectors and 2.6 pulley and a Stage 4 pcm by Intense. It was running great but still had the miss under a hard load around 5800 rpm's and every now and then a small poof of grey smoke and my dip stick would pop out. (making a friggin mess.) Well I wanted better pistons anyway so I tore it down and thats what I found. The #1 cylinder sleeve is a bit scuffed but nothing a good honing wont take care of I hope, but if not Im going to bore her. I believe running her as lean as I did for as long as I did was the problem all the other pistons look new, even #4.
So..... If you want BIG BOOST you need BIG INJECTORS and a good tune PERIOD!!
I'll have a update after work (The 4 of Nov) so stay tuned.
Old Nov 5, 2007 | 08:53 PM
My honer arrived and turned out GREAT!!
Going to reassemble when my pistons arrive.
Old Nov 12, 2007 | 09:58 PM
Just arrived!!!
Will be installing soon.
Old Nov 12, 2007 | 10:03 PM
Herndon_High_SS's Avatar
Super sexy.
Old Nov 12, 2007 | 10:04 PM
sPeEdInGsS's Avatar
good luck man keep us posted! you're pistions will be a lot more reliable now as you add on the power.
Old Nov 12, 2007 | 10:08 PM
bigjoe25's Avatar
i did the same thing but mine was number 2 and 3 pistons
Old Nov 12, 2007 | 10:09 PM
tlax23's Avatar
Mmmm nice.
Old Nov 12, 2007 | 10:12 PM
an0malous's Avatar
weeee
Old Nov 12, 2007 | 10:23 PM
spike's Avatar
THE SAME THING HAPPENED 2 MY #1 CYLINDER...............it sucked but my pistons will be here 11\13.............. i thought this only happen 2 my 1st cyl................we rock........haha
Old Nov 17, 2007 | 09:36 PM
Almost done! Just need to put the valve cover on and hook up the electrical. She should be breathing again Monday. OOOOOOHHHHHH im sOOOOOOOO EXCITIED!!!!!!
Old Nov 17, 2007 | 09:45 PM
All you did was pistons, right? About how long would you say the process was from start to finish? Anything really unusual that must be done while working on it?
Old Nov 17, 2007 | 10:12 PM
Well im an auto technician. I took me 1.5 hrs to completely tear down. half hour to hone cylinder walls and install pistons, half hours cleaning parts and 2 hours to reassemble. I work on it a half an hour at a time "lunch break". Most of the time I was waiting for gaskets and and orings. So in total I have approx 4 to 5 hrs vested.
"Anything really unusual that must be done while working on it?"
Answer: Make sure your 60 degress b4 TDC before tearing down and DONT drop the timing chain.
