Looking for immediate Help!
Old Mar 27, 2012 | 01:32 AM
Jbartock's Avatar
Got parts in last week and just got chance to install. So far I have installed forge BPV, K&N SRI, and Injen charge pipe. Everything tightened and set to go I turn the key and get a click click click. Then started throwing check lights and I shut car off and unhooked battery... Any recommendations??? 2010 cobalt ss/tc
Old Mar 27, 2012 | 01:40 AM
bluebalt07's Avatar
Clicking is usually a sign of a dead battery. And by check lights do you mean actual codes or just lights on the dash? Because if it's just lights on the dash, it's normal for them to come on until the car is started
Old Mar 27, 2012 | 01:48 AM
ssyellow's Avatar
If you have codes I would start with those.....
Old Mar 27, 2012 | 01:50 AM
Jbartock's Avatar
No reason for battery to be dead though and had power last night turned over after install of parts. Didn't actually drive though. So I got in it tonight turned key and clicked a few times showed the normal dash lights and this it started with check traction control, check abs, check esc, then I switched it off and unhooked battery. 3 simple bolt-ons just installed followed instructions as well as all the advice found through forms etc etc.
Old Mar 27, 2012 | 10:00 PM
bluebalt07's Avatar
You still haven't proven anything. You need to either scan for codes or check the voltage on the battery to see which is causing the problem
Old Mar 27, 2012 | 10:02 PM
Mr.Tozzi's Avatar
^ agreed.
It really just sounds like you ran out of juice in the battery.
Old Mar 27, 2012 | 10:13 PM
Malaclypse's Avatar
Fix the battery first.
A bad battery will set all kinds of crazy codes.
Old Mar 28, 2012 | 02:12 PM
Jbartock's Avatar
was loose on the positive post, unhooked both posts and left for awhile, reconnected and good to go.
Old Mar 28, 2012 | 02:14 PM
cobaltguy889's Avatar
I was just going to say to tighten your battery clamps lol
