loud clicking from behind dash "fix"
Old Jun 4, 2012 | 03:21 AM
Galadrake's Avatar
I posted this over in general cobalt but I figure it should probably be here instead.
Hey there, I know a lot of people are gettin the loud clicking from the passenger side inside the dash when they turn they're key on. As you may know its the actuator for the door that controls the recirculate function inside the airbox . Everyone seems to believe you have to tear your dash apart to disable it. If you have small enough hands and a little patience, there is an easier way to unplug it and not have to hear the annoying noise every time you go to jump in your car. I unplugged mine (its not working anyway because the gears in the actuator are stripped) and it doesn't affect the heat or air conditioning at all, just the recirculate function. If you scoot the passenger seat all the way back, and lay on your back on the floor, reach up above the side kick panel in the small space between the dash and the body of the car in front of the passenger door. Its about six inches up, you'll find two small wires taped together (not the wires for the blower motor!). Follow them up to a plug. You cant see in there so its all by feel. Theres a blue plastic key you have to snap out with your fingernail, then just give the plug a firm tug and it should pop right out. Mine has been working great and I done have to hear the horrible noise anymore. Hope this helps guys, and good luck!
Old Jun 4, 2012 | 07:46 AM
06SS ALL DAY's Avatar
Well done. I'm sure a lot of people will do this lol. I use the recirculate time to time but either way you figured out how to rid of that damn noise! Thanks lol
biniecki
Oct 25, 2015 02:23 PM
OrangeK
Sep 20, 2015 03:02 AM
Infamous SC/SS
Sep 4, 2015 05:33 PM
Adam144
Sep 3, 2015 07:48 PM
