LS4 TB installed...codes
Old Nov 10, 2008 | 10:32 PM
M88ArRamadi's Avatar
I installed my NBS, Cam Gears, TVS, and LS4 TB last night. I have the following codes:
P0507 Idle Speed High ECM, PCM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance- ECM, PCM
P2119 Throttle Closed Position Performance ECM, PCM
Sorry for the noob questions...been out of the car scene for a year now....
My question is when I re-timmed tht engine do I have to do a case relearn? The PCM is the same and don't get the CASE relearn code but I get alot of TB codes. I solved the P0532 and P0068. I'm wondering if the TB is a lemon or I need to relearn.
BTW: I changed the P0068 to 8000 RPM to solve that one. I increased the other one (can't remember right now) to 4500.000.
Old Nov 10, 2008 | 11:17 PM
Sharkey's Avatar
you need to change something in the pcm for the ls4 throttle body. im not sure exactly what it is (scalar factor or something like that). if you didnt it may be whats causing the issues
Old Nov 10, 2008 | 11:23 PM
I followed the instructions on this thread:
https://www.cobaltss.net/forums/show...light=big+bore
Old Nov 11, 2008 | 01:57 PM
help..............
well I put the stocker back on.....no codes now.
Last edited by M88ArRamadi; Nov 11, 2008 at 01:57 PM. Reason: Automerged Doublepost
Old Nov 11, 2008 | 02:03 PM
Tennpenn83's Avatar
if your idle etc scalar is set to 4500.000 then i have no idea what to tell you
check all your connections again, i had a vacuum hose or whatever it is blow off on mine one time
was your ls4 tb used or new?
Old Nov 11, 2008 | 03:25 PM
used
Old Nov 11, 2008 | 07:00 PM
Tennpenn83's Avatar
Originally Posted by M88ArRamadi
used
might well be a dud then... i don't know what to tell you
Old Nov 11, 2008 | 07:02 PM
BoostedYards86's Avatar
have fun with the tvs though hahaha.
Old Nov 11, 2008 | 07:21 PM
Tennpenn83's Avatar
Originally Posted by BoostedYards86
have fun with the tvs thoguht hahaha.
yeah no ****...
Old Nov 11, 2008 | 07:34 PM
wow i can't spell
Old Nov 11, 2008 | 07:56 PM
I'm not sure what pulley I have on but.......I hit 23 PSI! I have a much smaller one but decided to go with the middle size. the boost guage maxes out and starts to go below the "boost" writing then freaks out and resets! Car pulls wicked hard!
Old Nov 11, 2008 | 08:14 PM
thats awesome haha
i really need to get one of those at some point.
Last edited by BoostedYards86; Nov 11, 2008 at 08:14 PM. Reason: Automerged Doublepost
Old Nov 11, 2008 | 08:21 PM
Tennpenn83's Avatar
what cooling do you have?
Old Nov 11, 2008 | 08:28 PM
dual pass and meth
Old Nov 13, 2008 | 03:24 PM
well I returned the TB for another one...updates to come
Old Nov 13, 2008 | 08:22 PM
Tennpenn83's Avatar
cool let us know
Old Nov 13, 2008 | 08:35 PM
lsjwannabe's Avatar
thats the 2.75" your running closer to 25 psi
Old Nov 13, 2008 | 08:40 PM
G85 SS's Avatar
*sigh* I wish I had the money for a TVS.
Old Nov 13, 2008 | 11:13 PM
Cool....well I know I have the 2.5 and the 2.75.....lsjwannabe what's the other size I have?
60lb injectors are at 110% 17* and scan guage reads 449 hp....I KNOW IT'S ONLY A SCAN GAUGE AND NOT ACURATE...SO DON'T FLAME ME!!!! When I come home for good in Feb I will get a better tune and real dyno numbers. I really want to hit the 400hp mark with a SC.
Old Nov 14, 2008 | 12:31 AM
lsjwannabe's Avatar
3.35" what mix of meth are you spraying?
Old Nov 14, 2008 | 12:49 AM
50/50 devils own
SmitBag
Sep 7, 2016 08:05 AM
goaliemo
Sep 28, 2015 01:37 PM
n20saturn
Sep 21, 2015 01:50 AM
yellowsupercharged06
Sep 15, 2015 04:38 PM
aikidoshadow
Jan 9, 2009 04:55 PM
