LSJ oil pressure?
Old Mar 30, 2014 | 10:18 PM
josh6854's Avatar
LSJ oil pressure?
I have a glowshift oil press gauge and it seemed to work fine for the first few days but now the numbers jump much higher. It sits around 30ish when started or idle but on the highway about 60 70. Lastnite I was driving and my meter shot past 130 140 150 and was resetting and all kinds of crazy. Any ideas?
Old Mar 30, 2014 | 10:20 PM
Joe09SS's Avatar
Was it moving really fast, so fast you could hear the needle moving swiping back and forth?
Old Mar 30, 2014 | 10:44 PM
josh6854's Avatar
its digital and the numbers would jump crazy high and if i stop it would go back to normal
Old Mar 30, 2014 | 11:01 PM
Axelthered05's Avatar
check the ground on your sensor, glowshift's screw terminal sensors tend to come unscrewed, then your screwed
Old Mar 31, 2014 | 06:59 AM
Joe09SS's Avatar
Exactly what I was gonna say.
If you can. Solder.
Old Apr 1, 2014 | 10:25 PM
josh6854's Avatar
I have my oil pressure gauge and air fuel gauge on the same ground do you think thats also why my af gauge needle doesn't move as well as my oil pressure gauge acting funny?
Old Apr 1, 2014 | 10:48 PM
Joe09SS's Avatar
If its not the best ground then yes. Gotta get a good solid ground and at best solder if splicing two wires together...
However it doesn't matter how many ground wires you have going to one wire to a ground.
What I'm trying to say is consolidate your grounds close to the sensors then use 1 wire to ground all.
Old Apr 5, 2014 | 01:13 AM
josh6854's Avatar
Thank you haven't been on here due to work but I will check that out.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
Trav3480
Oct 1, 2015 08:17 PM
