LSJ Throwing P0449
Old May 19, 2012 | 10:30 AM
ShelbyZ's Avatar
LSJ Throwing P0449
My car (2006 IRL) has been throwing a P0449. I replaced the solenoid under the hood next to the valve cover and cleared the code, but it came back. What should my next plan of action be?
Old May 19, 2012 | 10:38 AM
Chevycobaltss3's Avatar
Purge valve. On canister under car. If you still get a cel, look for a leak within the evap system
Old May 30, 2012 | 06:58 PM
ShelbyZ's Avatar
I changed out the solenoid on the purge canister and the code still came back... what next?
Old May 30, 2012 | 07:11 PM
Sunburst_SS's Avatar
that code is for a vent solenoid control circuit........the part you replaced under the hood is the purge solenoid and would not cause this dtc to set. You need to check the power and ground circuit to the canister vent valve (back by the fuel tank) and if the circuits test good you need to replace that vent valve.
Old May 31, 2012 | 08:11 AM
ShelbyZ's Avatar
Thats what I canged out yesterday and its still throwing the code.
Old May 31, 2012 | 06:58 PM
so you cleared the code and it came back?
You need to check the power and ground circuit to the vent valve.
Old May 31, 2012 | 07:07 PM
and you are setting the same code?
Old May 31, 2012 | 07:12 PM
well, if there was a leak in the evap system....it is possible that the code would set since the system would not hold a vaccum.
Old May 31, 2012 | 07:21 PM
well, if that like is broken.....I assume it is from the charger to the purge solenoid is broken.....when the purge solenoid opens there would be no engine vaccum available at the solenoid to pull vaccum on the evap system......which would show a leak (basically). But to make sure they are working if you wanted to check the ciruicts you would use a multi meter or even a test light.....
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
