Mass Air Flow Schematic
Does anyone have a schematic that shows what each wire is/does on the MAF sensor?
Please and thank you |
I'd try to get ahold of someone at your gm parts place. They might be able to get you something.
Other than that you could try talking to these guys: http://www.maftpro.com/ they make maf translators. Could be some help |
Thanx, but i need to see the actual wiring diagram.
In my truck, I have the same MAF sensor as the Redline. But in the 2007 models of my truck, they are running the same MAF as the cobalts. The only difference between the Cobalt MAF set up in my truck, compared to my current one, is the last two wires on the plug, are reversed. So I wanted to compare schematics, to see if I just switched the wires around, could I run the 07 MAF sensor. |
why would you want to? what are you expecting to gain?
what year is your truck, and what engine?? I can get the pin outs
Originally Posted by RaineMan
(Post 1459988)
it's not to gain anything, its for my own personal reasons and experimentation
I drive a 2006 I4 Chevrolet Colorado Xtreme I want to change my MAF set up to that of the 2007 I4 Chevrolet Colorado Xtreme If you can get me the pin outs for those two, instead of my truck on the cobalt, that would be 100 times better. Please and thank you. |
ok....2007 2.2 cobalt
Pin A, wire color yellow, MAF sensor signal. Pin B, wire color black/white, Ground. Pin C, wire color pink/black, Ignition 1 voltage. Pin D, wire color Tan, Low Reference. Pin E, wire color Tan, IAT Sensor Signal pin outs are the same for 2006. there you go |
Originally Posted by Sunburst_SS
(Post 1460193)
