Mass Air Flow Schematic
Old Sep 17, 2007 | 06:54 PM
Xtreme4U2NV's Avatar
Does anyone have a schematic that shows what each wire is/does on the MAF sensor?
Please and thank you
Old Sep 17, 2007 | 07:25 PM
Novajoe's Avatar
I'd try to get ahold of someone at your gm parts place. They might be able to get you something.
Other than that you could try talking to these guys:
http://www.maftpro.com/
they make maf translators. Could be some help
Old Sep 17, 2007 | 07:42 PM
Thanx, but i need to see the actual wiring diagram.
In my truck, I have the same MAF sensor as the Redline. But in the 2007 models of my truck, they are running the same MAF as the cobalts.
The only difference between the Cobalt MAF set up in my truck, compared to my current one, is the last two wires on the plug, are reversed.
So I wanted to compare schematics, to see if I just switched the wires around, could I run the 07 MAF sensor.
Old Sep 17, 2007 | 07:45 PM
RaineMan's Avatar
why would you want to? what are you expecting to gain?
Old Sep 17, 2007 | 07:47 PM
Sunburst_SS's Avatar
what year is your truck, and what engine?? I can get the pin outs
Old Sep 17, 2007 | 07:52 PM
halfj99's Avatar
im with him /\
Old Sep 17, 2007 | 08:02 PM
it's not to gain anything, its for my own personal reasons and experimentation
I drive a 2006 I4 Chevrolet Colorado Xtreme
I want to change my MAF set up to that of the 2007 I4 Chevrolet Colorado Xtreme
If you can get me the pin outs for those two, instead of my truck on the cobalt, that would be 100 times better.
Please and thank you.
Old Sep 17, 2007 | 08:40 PM
ok....2007 2.2 cobalt
Pin A, wire color yellow, MAF sensor signal. Pin B, wire color black/white, Ground. Pin C, wire color pink/black, Ignition 1 voltage. Pin D, wire color Tan, Low Reference. Pin E, wire color Tan, IAT Sensor Signal
pin outs are the same for 2006. there you go
Old Sep 17, 2007 | 09:15 PM
thank you kindly good sir
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
goaliemo
Sep 28, 2015 01:37 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
