Misfire po300
Old Apr 4, 2012 | 01:36 PM
impala7679's Avatar
Misfire po300
I recently started get ting misfires on cyclinder 2 . I swapped coils to see if the misfire would follow ,but it didnt. I have ngk iridiums and i dont if its the plugs or the 60lb injectors or something else?
Old Apr 4, 2012 | 10:42 PM
bluebalt07's Avatar
If you are getting misfires only on #2 it should be a p0302 code. p0300 is a random cylinder misfire code. That being said what are your plugs gapped to? It could be injectors or plugs but either way if it is p0300 and not p0302 it shouldn't be anything to worry about. I get and clear this code pretty much everyday
Old Apr 4, 2012 | 10:48 PM
impala7679's Avatar
Well the problem is the car is sputtering when going 2 second gear. or hard accerlation. Plugs cant be gapped , o reillys said they couldnt be gapped becuase of the iridium.
Old Apr 4, 2012 | 10:49 PM
mexi_loco's Avatar
It would be easier to start with soapy water and spraying around your injectors. Get a boost leak tester and check for leaks. Chances are you will either expose an injector that isn't seated properly, or a bad o-ring on your injector housing. If there's no leaks, then I would go ahead and pull the plugs and see what your gap is.
I'm assuming your an lsj, correct? You shouldn't put iridiums in there anyway. A lot of people will argue with me on this point, b/c everyone thinks iridium is so ******* awesome. Go back to O'reilley or "Vato-zone" or wherever, get the NGK's that are suppose to go in that block and make sure to gap them properly.
Old Apr 4, 2012 | 11:49 PM
impala7679's Avatar
Correct lsj. So with that be said should I gap my plugs to .035 since im.lightly moded. And copper?
Old Apr 5, 2012 | 12:01 AM
mrbelvedere's Avatar
4644 is the stock number to the ngk 1 step colder plugs gap them to .032 some have had good luck with irridiums most havent
Old Apr 5, 2012 | 12:20 AM
bluebalt07's Avatar
Even the 1 step colder plugs are usually iridium, they just have a copper core. And you can gap them, you just have to use an actual gap tool instead of a tapered gap gauge
Old Apr 5, 2012 | 08:05 AM
mexi_loco's Avatar
the ngks that come with the lsj's are NOT iridium
Old Apr 5, 2012 | 09:14 AM
wrong the 1 step colder plug for the lsj is not iridium can you get sure if you want
Old Apr 5, 2012 | 11:03 AM
impala7679's Avatar
Im going change my plugs then and gap them. Ill see if the misfires/ sputtering goes away
Old Apr 5, 2012 | 11:04 AM
impala7679's Avatar
By the way im not dynoed,yet ,would this cuase the sputtering?
Old Apr 5, 2012 | 11:25 AM
tbellazzi's Avatar
curious how this is working out for you..? This was the start of my nightmare, which ended up becoming a bad oil retaining ring on piston one...
still not sure if they were related issues, but always had a random misfire that was later related to cylinder 1 which caused sputtering...
tried switching out plugs and new fuel injectors....thought everything was fine, then had the plug blow out...
i was running the ngk iridiums myself
good luck...curious if your plugs and propper gapping will help
ps getting dyno'd has nothing to do with the sputtering unless your gonna get tuned while running on the dyno
Old Apr 16, 2012 | 09:32 PM
impala7679's Avatar
well i finally bought plugs and tried different gaps(.032,.034,.035,.036),but still getting a misfire . . What now look for a bad injector?
Old Apr 16, 2012 | 09:46 PM
bluebalt07's Avatar
Is it misfiring all the time, just at idle, or randomly?
Old Apr 16, 2012 | 10:50 PM
impala7679's Avatar
only under acceleration.
Old Apr 17, 2012 | 01:08 AM
bluebalt07's Avatar
Could be a bad injector not pushing enough fuel. If the misfire is specific to a cylinder just swap that injector with another one and see if the misfire follows.
Old Apr 17, 2012 | 08:07 AM
mexi_loco's Avatar
Any kind of acceleration? Or whenever you go into boost?
Old Apr 17, 2012 | 11:10 AM
impala7679's Avatar
About 5 lbs of boost it varies. Sometime even lower, but ill try swapping injectors.
Old Apr 17, 2012 | 07:42 PM
mexi_loco's Avatar
check your bolts that hold down your fuel rail. I bet there's one loose. Ask me how I know
Old Apr 20, 2012 | 01:16 PM
impala7679's Avatar
I swapped injector 2 and 3 and scanned it . misfire followed to # 3. I then pulled the fuel rail and looked if there was any diffrences in spray patterns and surely there was,made a big mess. Im going to seafoam it now. Thanks guys for the help!..
Old Apr 20, 2012 | 07:47 PM
mexi_loco's Avatar
i don't think sea foam will help it any. But you're more than welcome to try.
Old Apr 20, 2012 | 07:49 PM
05Slowline's Avatar
or intake manifold bolt is loose
Old Apr 20, 2012 | 08:01 PM
mexi_loco's Avatar
did i mention 5 of my intake mani bolts were loose last time i did a boost leak test
Old Apr 21, 2012 | 12:18 PM
impala7679's Avatar
Your right seafoam didnt work sucks. I called zzp and a ordered a new injector.
Old Apr 23, 2012 | 11:11 PM
kissmy05ss's Avatar
when you said you havent dynoed yet... do you mean you arent tuned?
