More Carbon
heres a pic of the serious carbon im getting. I email scott at intense and he assured me that the pcm was set. Hes sending me a new set of spark plugs maby the old ones are bad or not gaped right. he wants me to take the injen off tho, says it may be messing up the pcm. This is what its doing every start up
http://i28.photobucket.com/albums/c236/thes25/kkpp.jpg |
damn...
umm, that dosnt look good....
damn i dont think mines that bad
yeah, that why im trying to figure out wuts up
I get a little bit at start up but mines up where the mufflers meets the resonator section. I have a small leak I need to fix but its not that bad.
mmm tasty
Looks like your car has the runs.
That looks pretty bad, I saw that on my cougar after it sat for the winter.
well intense pretty much told me flat out that im to rich, and its the injen intake that causing the pcm to go haywire because its destorting the MAF. So looks like itl be the air box mod for me
1st of all there are many guys with Intense tunes and an intake without carbon issues. 2nd, an intake would make you run lean not rich. 3rd, I have an Injen CAI and my MAF is fine along with most other people. |
Looks like your car took a SHIT!
Hope everything works out :thumb: |
Originally Posted by CTCOBALTSSS
I don't know about that bro!
Yeah thats where i get confused, i was running fine until i took it into the dealer to have a clutch put in. now he said he didnt reflash it but how knows for sure. But when i went on intense to look and see it said they if they reflashed it all the info would be gone. Its running ok, and it still redlines at 7 grand. Its just insainly rich. When i got it back from the dealer i felt a serious loss in power. But i bein retraining the pcm for hard driving little buy little and ive gotten most of the power back.
I'm sorry bro, I don't know. The only other thing I can think of is your CAT is shot and it's letting a lot of carbon through the exhaust. Stock CATs are notorious for failing even when your stock. Now that you have stage 3 chances are that's what it is. |
Keep us informed in how this works out for you. Hopefully it's all good in the end.
I have the same problem but no where near that, I know some exhaust systems have water that travels out of the pipes and at times sprays at WOT. I have to ask, what Octane are you putting in the car? If you put 91 in the car that's your first problem. Shit gas does that mostly, not what has been altered to the car.
no def 93 octane
no def 93 octane
got the tune, running fine no carbon. Took to the dealer to have clutch done. Carbon started happening. scott at intense assured me my tune was fine because if they reflashed it the the engine would be running like poo and my rev limiter of 7 grand would be gone. adits all still there.
I only get bad caron deposits on the ground if
1) Car sat too long off 2) Bad Tank of Gas 3) Gummed up Exhaust system 4) Car was ran really hard as of late |
lmfao... Damn man I hope you can get that fixed.
i think its just the intakes for this car. seems like nothing but trouble has happened witht hese intakes. if i didnt already have one and like the sound. i wouldnt have one.
thats whats good about the XTC doesn't mess around with the stock maf position... just fixes the tubing to the s/c 3" all the way
