More Carbon
Old Sep 7, 2006 | 02:27 PM
TheYellowSS's Avatar
More Carbon
heres a pic of the serious carbon im getting. I email scott at intense and he assured me that the pcm was set. Hes sending me a new set of spark plugs maby the old ones are bad or not gaped right. he wants me to take the injen off tho, says it may be messing up the pcm. This is what its doing every start up
Old Sep 7, 2006 | 02:28 PM
06blackg85ss's Avatar
damn...
distillion's Avatar
umm, that dosnt look good....
Old Sep 7, 2006 | 02:31 PM
yeah, that why im trying to figure out wuts up
carbombss's Avatar
damn i dont think mines that bad
Old Sep 7, 2006 | 02:35 PM
Ern's Avatar
Ern
I get a little bit at start up but mines up where the mufflers meets the resonator section. I have a small leak I need to fix but its not that bad.
Old Sep 7, 2006 | 02:36 PM
OniMirage's Avatar
mmm tasty
Old Sep 7, 2006 | 02:46 PM
Tomtwtwtw's Avatar
Looks like your car has the runs.
Stilgar's Avatar
That looks pretty bad, I saw that on my cougar after it sat for the winter.
Old Sep 7, 2006 | 02:53 PM
well intense pretty much told me flat out that im to rich, and its the injen intake that causing the pcm to go haywire because its destorting the MAF. So looks like itl be the air box mod for me
Old Sep 7, 2006 | 02:56 PM
CTCOBALTSSS's Avatar
I don't know about that bro!
1st of all there are many guys with Intense tunes and an intake without carbon issues.
2nd, an intake would make you run lean not rich.
3rd, I have an Injen CAI and my MAF is fine along with most other people.
Old Sep 7, 2006 | 02:59 PM
HackAbuse's Avatar
Looks like your car took a ****!
Hope everything works out
Old Sep 7, 2006 | 03:07 PM
Yeah thats where i get confused, i was running fine until i took it into the dealer to have a clutch put in. now he said he didnt reflash it but how knows for sure. But when i went on intense to look and see it said they if they reflashed it all the info would be gone. Its running ok, and it still redlines at 7 grand. Its just insainly rich. When i got it back from the dealer i felt a serious loss in power. But i bein retraining the pcm for hard driving little buy little and ive gotten most of the power back.
Old Sep 7, 2006 | 03:10 PM
Yeah man I don't get it. I wish I could help but like I said a couple posts ago, most people are fine. Even if they reflashed your PCM a 2.8" pulley wouldn't run that rich.
I'm sorry bro, I don't know. The only other thing I can think of is your CAT is shot and it's letting a lot of carbon through the exhaust. Stock CATs are notorious for failing even when your stock. Now that you have stage 3 chances are that's what it is.
Old Sep 7, 2006 | 03:28 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Keep us informed in how this works out for you. Hopefully it's all good in the end.
Old Sep 7, 2006 | 03:31 PM
BLKSS's Avatar
It needs a pick me upper.
Old Sep 7, 2006 | 03:38 PM
3fo893013L's Avatar
I have the same problem but no where near that, I know some exhaust systems have water that travels out of the pipes and at times sprays at WOT. I have to ask, what Octane are you putting in the car? If you put 91 in the car that's your first problem. **** gas does that mostly, not what has been altered to the car.
Old Sep 7, 2006 | 03:47 PM
no def 93 octane
Old Sep 7, 2006 | 03:52 PM
3fo893013L's Avatar
no def 93 octane
hmph. mmkay. Not sure then. Carbon before and after tune?
Old Sep 7, 2006 | 03:57 PM
got the tune, running fine no carbon. Took to the dealer to have clutch done. Carbon started happening. scott at intense assured me my tune was fine because if they reflashed it the the engine would be running like poo and my rev limiter of 7 grand would be gone. adits all still there.
Old Sep 7, 2006 | 04:13 PM
3fo893013L's Avatar
I only get bad caron deposits on the ground if
1) Car sat too long off
2) Bad Tank of Gas
3) Gummed up Exhaust system
4) Car was ran really hard as of late
Old Sep 7, 2006 | 05:22 PM
cashstacker's Avatar
lmfao... Damn man I hope you can get that fixed.
Old Sep 7, 2006 | 05:26 PM
BallsoutBalt's Avatar
Why not just get a custome tune?
Old Sep 7, 2006 | 05:33 PM
JCswoosher2's Avatar
i think its just the intakes for this car. seems like nothing but trouble has happened witht hese intakes. if i didnt already have one and like the sound. i wouldnt have one.
Old Sep 7, 2006 | 06:25 PM
thats whats good about the XTC doesn't mess around with the stock maf position... just fixes the tubing to the s/c 3" all the way
