More Carbon
Old 09-07-2006, 02:27 PM
TheYellowSS's Avatar
More Carbon
heres a pic of the serious carbon im getting. I email scott at intense and he assured me that the pcm was set. Hes sending me a new set of spark plugs maby the old ones are bad or not gaped right. he wants me to take the injen off tho, says it may be messing up the pcm. This is what its doing every start up
Old 09-07-2006, 02:28 PM
06blackg85ss's Avatar
damn...
distillion's Avatar
umm, that dosnt look good....
Old 09-07-2006, 02:31 PM
yeah, that why im trying to figure out wuts up
carbombss's Avatar
damn i dont think mines that bad
Old 09-07-2006, 02:35 PM
Ern
Ern's Avatar
I get a little bit at start up but mines up where the mufflers meets the resonator section. I have a small leak I need to fix but its not that bad.
Old 09-07-2006, 02:36 PM
OniMirage's Avatar
mmm tasty
Old 09-07-2006, 02:46 PM
Tomtwtwtw's Avatar
Looks like your car has the runs.
Stilgar's Avatar
That looks pretty bad, I saw that on my cougar after it sat for the winter.
Old 09-07-2006, 02:53 PM
well intense pretty much told me flat out that im to rich, and its the injen intake that causing the pcm to go haywire because its destorting the MAF. So looks like itl be the air box mod for me
Old 09-07-2006, 02:56 PM
CTCOBALTSSS's Avatar
I don't know about that bro!
1st of all there are many guys with Intense tunes and an intake without carbon issues.
2nd, an intake would make you run lean not rich.
3rd, I have an Injen CAI and my MAF is fine along with most other people.
Old 09-07-2006, 02:59 PM
HackAbuse's Avatar
Looks like your car took a ****!
Hope everything works out
Old 09-07-2006, 03:07 PM
Yeah thats where i get confused, i was running fine until i took it into the dealer to have a clutch put in. now he said he didnt reflash it but how knows for sure. But when i went on intense to look and see it said they if they reflashed it all the info would be gone. Its running ok, and it still redlines at 7 grand. Its just insainly rich. When i got it back from the dealer i felt a serious loss in power. But i bein retraining the pcm for hard driving little buy little and ive gotten most of the power back.
Old 09-07-2006, 03:10 PM
Yeah man I don't get it. I wish I could help but like I said a couple posts ago, most people are fine. Even if they reflashed your PCM a 2.8" pulley wouldn't run that rich.
I'm sorry bro, I don't know. The only other thing I can think of is your CAT is shot and it's letting a lot of carbon through the exhaust. Stock CATs are notorious for failing even when your stock. Now that you have stage 3 chances are that's what it is.
Old 09-07-2006, 03:28 PM
LSX RWD S/C conversion
victory_red_SS's Avatar
Keep us informed in how this works out for you. Hopefully it's all good in the end.
Old 09-07-2006, 03:31 PM
BLKSS's Avatar
It needs a pick me upper.
Old 09-07-2006, 03:38 PM
3fo893013L's Avatar
I have the same problem but no where near that, I know some exhaust systems have water that travels out of the pipes and at times sprays at WOT. I have to ask, what Octane are you putting in the car? If you put 91 in the car that's your first problem. **** gas does that mostly, not what has been altered to the car.
Old 09-07-2006, 03:47 PM
no def 93 octane
Old 09-07-2006, 03:52 PM
3fo893013L's Avatar
no def 93 octane
hmph. mmkay. Not sure then. Carbon before and after tune?
Old 09-07-2006, 03:57 PM
got the tune, running fine no carbon. Took to the dealer to have clutch done. Carbon started happening. scott at intense assured me my tune was fine because if they reflashed it the the engine would be running like poo and my rev limiter of 7 grand would be gone. adits all still there.
Old 09-07-2006, 04:13 PM
3fo893013L's Avatar
I only get bad caron deposits on the ground if
1) Car sat too long off
2) Bad Tank of Gas
3) Gummed up Exhaust system
4) Car was ran really hard as of late
Old 09-07-2006, 05:22 PM
cashstacker's Avatar
lmfao... Damn man I hope you can get that fixed.
Old 09-07-2006, 05:26 PM
BallsoutBalt's Avatar
Why not just get a custome tune?
Old 09-07-2006, 05:33 PM
JCswoosher2's Avatar
i think its just the intakes for this car. seems like nothing but trouble has happened witht hese intakes. if i didnt already have one and like the sound. i wouldnt have one.
Old 09-07-2006, 06:25 PM
thats whats good about the XTC doesn't mess around with the stock maf position... just fixes the tubing to the s/c 3" all the way
Quick Reply: More Carbon
