My breaks
Old Jan 25, 2014 | 04:46 PM
tylererwin94's Avatar
My breaks
Hello everyone I have a problem with my brakes. My car is a 2006 2.0 lsj cobalt ss. When I push them hard they will work but if I push them lightly they go right to the floor but come back up to normal position. We have bled the brakes to pure fluid. There's no leaks coming from anywhere dose anyone know what could be the problem. Or has anyone had this same experience
Old Jan 25, 2014 | 05:13 PM
blueLNFftw's Avatar
Are the pads and rotors new?
Old Jan 25, 2014 | 05:14 PM
Yes pads and rotors are new.
Old Jan 25, 2014 | 05:18 PM
Cobalt_Daddy's Avatar
flex lines collapsed to them maybe?
happened on my accord. caused the brakes to lock up on one side.
just a guess could cause this maybe?
Old Jan 25, 2014 | 05:50 PM
The breaks work all around when u mash the break pedal it don't loose nothing but when u ease into the breaks it looses all holding and just goes to the floor and catches at the very end
Old Jan 25, 2014 | 05:51 PM
blueLNFftw's Avatar
Check all of the soft lines and see if they are collapsed or ballooning under heavy pressure.
If all is good look at the master cylinder
Old Jan 25, 2014 | 05:56 PM
Soft lines? I'm fairly new to fixing **** on my own so give me some more detail plz
Old Jan 25, 2014 | 06:24 PM
Brakes***
Old Jan 25, 2014 | 07:28 PM
blueLNFftw's Avatar
The rubber lines that go from the body of the car to the "axle"
Old Jan 26, 2014 | 01:25 AM
05g5's Avatar
^^ yea, they are probably what? 6-8 inchs long , black rubber. if your not sure wtf we talkin about, crank the wheel one way, you will see
Old Jan 27, 2014 | 06:12 AM
I checked them they was fine I'm buying a brake booster and gonna c if that is the problem it's the only thing I can think is bad.
Old Jan 27, 2014 | 06:45 AM
blueLNFftw's Avatar
Doubt it is going to be the booster.
More likely the master.
How does your clutch feel though?
Old Jan 28, 2014 | 11:38 AM
Doony's Avatar
good way to test the booter is to pump the brakes when the key is off, the pedal should be come hard then turn the key on and the pedal should go to normal if the booster is working.
Turbo Johnny
Feb 21, 2019 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Getaway_Driver
13
Aug 30, 2015 02:44 PM
ss xtreme
Feb 26, 2005 01:03 PM
