N E 1 hav prob's w shift lever???
I cant shift into reverse fast. It wont let me. Even tho the clutch is all the way in, the shifter doesnt go into reverse. I hold the clutch down and try to put it in Rev again but I hav 2 start over by puting the clutch all the way in and trying it again. Otherwise, if i force it itll sound like grinding on clunking under car. Sometimes it even does it going into 3rd while driving. Dealer cant duplicate the prob, LIKE ALWAYS.
PRECIATE D FEADBAQ
PRECIATE D FEADBAQ
If your having problems shifting then check this: under your cup holder (pops right up) are your two shift cables, there are two white plastic pieces (look like small blocks) at the front of each line. Push them down...if they click into place your problem is solved. Mine did this to me and I looked at the part and it was out of place. I just snapped it back down and it was done. Hope this helps.
The Rookie24
Sep 20, 2015 04:33 PM
