Need help
Old Jun 11, 2017 | 07:35 PM
Mattdog2020sc's Avatar
Need help
So broke my belt the other day at work so after couple days waiting on parts I replaced it fml.... Anyway now I have a superloud raddle on the side of motor sounds like timing chain..... Does anyone stock the balance and timing chain kit? I see crate engine depot has the separate kits is that it?.... And anyone in the Missouri area wanna make some cash fixing mine Lol.... Gm wants 950 give or take with parts...
Old Jun 11, 2017 | 08:51 PM
Post a video of the sound. If the belt broke you may have a bad bearing in one of the pullies.
Old Jun 11, 2017 | 08:54 PM
Ok with Photobucket?
Old Jun 12, 2017 | 10:08 AM
jdbaugh1's Avatar
Youtube works pretty good. Do you have a google or gmail account?
Also as Slowbalt said it could be a pulley bearing. I have had a pulley bearing go out and when it started making noise I really though it was the timing chain too. I even popped off my valve cover to make sure the tensioner was working correctly. Eventually the grinding noise stopped and this was the end result.
Old Jun 12, 2017 | 02:40 PM
Yea I have google and YouTube so ill put vid up n attach link. At first that's what I was thinking was my tensioner or idler on way out so I replaced the tensioner pulley just in case. .
Old Jun 12, 2017 | 04:00 PM
Video
https://youtu.be/rGjIfsUMERc
lmk what you guys think.
Old Jun 12, 2017 | 04:57 PM
jdbaugh1's Avatar
Could be your idler pulley just like mine. I ended up having a modify the idler pulley assembly so that I could replace the exploded pulley with a standard pulley for the tensioner. I dug and dug an dug for information on a replacement idler pulley but could not find one anywhere. If it is your pulley like it was on mine it should be exploding any time now. Does the sound sort of change at startup and then after it runs a while?
Old Jun 12, 2017 | 05:15 PM
Not really its pretty consistent
Old Jun 12, 2017 | 05:24 PM
Henry3959's Avatar
If you don't have an automotive stethoscope, remove the belt and spin each item, including the alternator.
Old Jun 12, 2017 | 05:27 PM
Ok I will I have off next 2 days ill pull belt and spin eveything.
Old Jun 12, 2017 | 05:32 PM
Henry3959's Avatar
I wouldn't run it anymore....
Old Jun 15, 2017 | 02:28 AM
So.... Im pretty sure its the pulley. Took better look qtoday and Im pretty sure the bearing is on its way out. Not the front tensioner but the one above the crank anyone have a part number?
Old Jun 15, 2017 | 07:47 AM
jdbaugh1's Avatar
The one above the crank is the idler pulley. Like I said earlier this pulley is very difficult to find by itself. When I went through this everyone thought the idler pulley and tensioner pulley were the same. I still never found the part number. Worst case you can machine your idler bracket to accept the same pulley as on the tensioner assembly.
Edit: Here is the thread I created when my pulley went out
Old Jun 15, 2017 | 12:11 PM
Im glad i saved you the trouble of replacing timing parts.
Old Aug 28, 2017 | 03:33 AM
Harmonic balancer
So replaced the belt and pulley fixed some noise pulled belt back off accessories and it's my harmonic balancer chattering and wobbling slightly. Car has been sitting for a while and just got time today. So I ordered it from O'Reillys. Any advice 3 jaw or???
Old Aug 31, 2017 | 02:38 PM
H.B. wobble
Anyone else have a harmonic balancer wobble?
Old Aug 31, 2017 | 02:39 PM
user 72239's Avatar
mine was making a horrible noise.
its just a bolt that holds it on. I believe its a 22mm. its torque to yield, so get a new one.
Old Aug 31, 2017 | 02:43 PM
Bought the balancer today fixing tomorrow.... I'm just worried I had a similar issue in one of my Taurus SHO' and it was crank cancer. .... had to weld new material around keyway and replace key and crank pulley. .... thanks...
