need help please!
Old Apr 18, 2008 | 11:39 PM
~Coby~Kid~'s Avatar
need help please!
ok so i was drive my car tonight and everything was fine. i shut my car off for about 15mins...then i start it back up and i dont have power steering, windshield wipers, and my airbag light is on. i know it is a fuse i know what on i put a new on in and it keeps blowing does anyone know why or how to fix it. it would help me greatly thanks
Old Apr 18, 2008 | 11:40 PM
silentd's Avatar
sounds like a short if u keep blowing the fuse
Old Apr 18, 2008 | 11:42 PM
~Coby~Kid~'s Avatar
help me please
ya i know but where? its the fues under the hood and its a 20amp
Old Apr 18, 2008 | 11:44 PM
silentd's Avatar
take it to the dealer if u can. DO NOT put in a bigger fuse. you would have to trace back the wires. what were u doing before you turned it off? driving wise?
Old Apr 18, 2008 | 11:45 PM
~Coby~Kid~'s Avatar
need help please!
racing down town with all my friends
Old Apr 18, 2008 | 11:52 PM
Cobalt Racer's Avatar
If ur blow'n tha fuses under tha hood, let tha dealer deal with it. U might be look'n at a bigger problem that u just can't see.
Old Apr 18, 2008 | 11:53 PM
silentd's Avatar
that is probably why this happened.. something came loose or shifted and pinched a cable or something. dealer would be the only option unless u want to rip apart your electrical system
Old Apr 18, 2008 | 11:57 PM
~Coby~Kid~'s Avatar
ok thanks guys i'm gonna go to the dealer tomorrow b/c its so damn hard to drive without power steering! thanks again!
Old Apr 18, 2008 | 11:58 PM
silentd's Avatar
ya its a bitch
Old Apr 19, 2008 | 01:20 PM
Dustin's Avatar
Might have been that "Jet" chip that's so damn good for your 2.2L's performance.
Old Apr 19, 2008 | 01:22 PM
Sunburst_SS's Avatar
yup, if you're blowing the fuse.....a wire is shorting to ground, need to find out which circuit it is and repair the wire.
Do you have any aftermarket electircal things on the car??/ Lights, gauges, etc.?
Old Apr 19, 2008 | 01:28 PM
blackjack hotrods's Avatar
You didn't say what fuse it was but I found this preliminary info bulletin.
#PIC4578A: EPS/STR Wheel Control Fuse (19#) Open - keywords cntrl EPS fuse19 inop inoperative int power stg steering system whl - (Aug 23, 2007)
Subject: EPS/STR Wheel Control Fuse (#19) Open
Models: 2005-2008 Chevrolet Cobalt
2006-2008 Chevrolet HHR
2005-2006 Pontiac Pursuit (Canada Only)
2007-2008 Pontiac G5
This PI was superseded to add second area for inspection, and add 2008 Model years. Please discard PIC4578.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer might complain that their power steering system is in "Default mode" and/or their Steering Wheel Radio Controls are inoperative. A condition has been identified through TAC cases that there is a common area for a wiring Short To Ground (STG) that could cause the EPS/STR Wheel control fuse to open.
Recommendation/Instructions:
There are two locations for wiring concerns:
First check for a STG in circuit # 1539 (PNK) wire behind the radio. This circuit has reportedly been shorted on the radio mounting bracket, and just below the radio bracket almost to the BCM mounting location.
Note: For ease of locating this STG remove the radio, HVAC control head, and the upper console trim panels and inspect for wiring/brace contact.
Second check for a STG in circuit # 339 (PNK) wire behind the drivers side air bag.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
