Need Help Quick!!
Old Sep 4, 2006 | 09:16 PM
wdsoccer's Avatar
Need Help Quick!!
So today I finished installing 2 LED lights under the dash. (one on drivers side and one on passangers side) now when I plug in my radar dector to the plug under the AC controls ot doesnt work!! I dont know why it isnt working. i installed the LEDs and connected them to a switch that i bought at auto zone. can someone tell me why the cigarette plug under the AC controls isnt working??
Old Sep 4, 2006 | 09:20 PM
HackAbuse's Avatar
Did you blow a fuse?
CobaltBurst's Avatar
maybe you grounded something out when you were wiring... check the fuse...
Old Sep 4, 2006 | 09:33 PM
wdsoccer's Avatar
Check what fuse?
Old Sep 4, 2006 | 09:38 PM
mkulrey13's Avatar
cehck wireing and fuse on the side of the dash on drivers side.
Old Sep 4, 2006 | 09:47 PM
wdsoccer's Avatar
Its on the passengers side. and which fuse? theres a bunch
Old Sep 4, 2006 | 09:48 PM
HackAbuse's Avatar
Theres also a fuse under the hood
Old Sep 4, 2006 | 10:38 PM
wdsoccer's Avatar
so which one do i need to check? would the fuse be the thing that makes it not work? the other cigarette lighter works (the one next to the E-brake)
Old Sep 4, 2006 | 10:40 PM
HackAbuse's Avatar
I did the same thing on my balt when I wired up my lighting
Its the fuse under the hood
I forget what it was labelled though
Start pulling fuses and find the burnt one
Edit: it was the trunk fuse
Old Sep 4, 2006 | 10:41 PM
wdsoccer's Avatar
so that should be the only thing thats making it not work even though the other cigarette plug works?
Old Sep 4, 2006 | 10:47 PM
HackAbuse's Avatar
yeah, i had the same problem
does your trunk open? that will tell you for sure
Old Sep 4, 2006 | 10:52 PM
wdsoccer's Avatar
my trunk opens....
Old Sep 4, 2006 | 10:54 PM
wdsoccer's Avatar
What else would it be???
Old Sep 4, 2006 | 11:07 PM
wdsoccer's Avatar
anyone else know what it could be?
Old Sep 4, 2006 | 11:08 PM
HackAbuse's Avatar
loose wire?
HackAbuse's Avatar
Take it into the dealer, i doubt they'll figure out it was your fault
Old Sep 4, 2006 | 11:11 PM
wdsoccer's Avatar
well i drilled a hole into the plastic next to the cigarette lighter. do you really think that they will fix it under warenty
Old Sep 4, 2006 | 11:20 PM
HackAbuse's Avatar
check the wire
Old Sep 5, 2006 | 08:04 AM
wdsoccer's Avatar
what am i going to check for in the wire? how many ground wires can i put in the same place? i have the ground from the switch, and 2 LEDS and underbody grounds in the same place
Old Sep 5, 2006 | 09:15 AM
wdsoccer's Avatar
ok so i took the center consuel apart again and i noticed that the cigarette plugs are different. the one next to the e-brake has some black thing inside it and the one below the AC controls doesnt have anything. i also noticed that when i plug in the radar to the plug under the AC, it doesnt go in as far as the other plug. can someone try this to see if that is my problem?
Old Sep 5, 2006 | 09:40 AM
wdsoccer's Avatar
come on guys i need some help here
Old Sep 5, 2006 | 06:00 PM
Lorenzo's Avatar
do you have a fluke(meter) or know how to use one??
Old Sep 5, 2006 | 06:06 PM
wdsoccer's Avatar
I have no idea what that is. lol
Old Sep 6, 2006 | 07:12 PM
wdsoccer's Avatar
Can anyone tell me what is wrong?
Old Sep 6, 2006 | 07:50 PM
HackAbuse's Avatar
I still say go thru and check all your fuses
