Need help with starter
Old Nov 17, 2013 | 06:16 PM
fafcobalt's Avatar
My crank sensor is bad and I have to pull the starter off I have been working on it it's in a hard to reach spot I've had to fight with it still no luck any help advice pics to make the simpler I've heard so many things there's only 2 bolts but I have 3 and I can't get the last one on top off any help thanks in advance
Old Nov 17, 2013 | 06:40 PM
Spawne32's Avatar
not sure where you got the third bolt from, maybe you unbolted the solenoid lol its removable, but it is a pain in the *****, you have to use a ratchet and a 6" extension and then use one hand to feel around in there and the other hand to hold the ratchet and guide it onto the bolt. Its only accessable from underneath.
Old Nov 17, 2013 | 07:17 PM
kzak104's Avatar
There's 2 bolts. Both going into the transmission. The one on top behind the starter just use an extension... Shouldn't take more then 3 minutes to drop the starter....
Old Nov 17, 2013 | 08:08 PM
Spawne32's Avatar
yeh 3 minutes, assuming youve had to remove your starter 100x before
Gugi96
Sep 15, 2015 12:24 AM
juandirtymessican
Oct 27, 2012 10:41 PM
loudog3114
Mar 28, 2007 07:45 PM
lnadeau
Dec 15, 2006 06:20 PM
5150studios
Sep 5, 2006 01:04 AM
