Need some help please
Old May 19, 2007 | 10:12 PM
Mikey851's Avatar
Okay guys, I have a STOCK 06' SS/SC with 9,400 miles on it. I bought it with 4,000 miles on it. I went to check my oil level and smelled it out of curiousity and it smelled like gas. I went on to try and see what the problem was. My dipstick has not popped out and the car has great power and does not smoke or anything. I rarely go WOT with it.
I went to get my oil changed and within two days the oil smelled like gas again. Still suspecting blow by as the culprit I wanted to investigate a little further. I started the car and let it idle and then took off the oil cap (I know that's not a great thing to do, but it's not that bad and did not set a CEL). There was quite a bit of air coming out that smelled of gas vapor; I have seen a similar thread to this but it didn't answer the question.
I also found a thread about a TSB where the intake manifold gasket allows boost to leak and cause crankcase pressure to occur.
So here's my question: Do you guys think that this is more than likely my problem (Intake gasket) or would you say it's something else? Seeing as the cars on warranty and I know how GM can be I do not want to dig around trying to fix the problem. I am going to leave everything on them as far as repair so they have no reason to question me.
Opinions appreciated.
Old May 20, 2007 | 03:28 AM
Blown 4-banger's Avatar
Maybe your running super uber ultra mega rich? Washing the cylinders and contaminating the oil with gas. I was tuning my friend, and for some reason, the car was commanding a 10.1 AFR!!!
Old May 20, 2007 | 03:47 AM
alaskacobalt's Avatar
Just take it to GM and let them figure them dig throught he crap satchel that you call your car... I love nothing more than being able to bring my car while under warranty. In fact since I have the extended warranty, I beg for **** to break. Sometimes I even remove my intake and pour water directly into the hole... just to see what happens... I figure I might as well get my money's worth and by that, I mean I want a new engine after 500 miles. ;0
Old May 20, 2007 | 01:47 PM
Mikey851's Avatar
Yeah, I was wondering about this as well. I pulled all of the plugs and all of them looked good with a tan tint to there insulators; they didn't look perfect but none of them stood out (could be because all of them were running rich).
The part I don't like is the gas smell coming from the oil filler hole and the oil on the dipstick. In the filler hole it smells like a vapor, and the oil smells like a mixture. This is why that TSB struck me as a possibility. Oh well, I'll just take it in to the dealership.
Hahaha, that's one way of looking at it I guess.
