NO air box? WTF...
Old Jun 1, 2009 | 04:44 PM
silverguns's Avatar
Exclamation NO air box? WTF...
So I bought my 06 SS/SC last year (May 2008) used with 18k miles on it.
After about a week after buying it my CEL came on. My bf said no biggie probably need a new O2 censor. So it's gone on and off for the last year and my car has never even idled weird.
So finally I decide to get the code for the error. They say it's running lean. (P0171)
I say "Ok, probably need a new O2 censor." I decided I need to go ahead and change out my air filter and had autozone order a K&N air filter.
Well, when we got down to change it, I have not freaking air box! Someone has basically removed the air box and "created" a CAI.
However, there's no fancy metal pipes.... Soo is this bad or does it matter?
Basically I have the stock (plastic) tubing with (now K&N) air filter just at the bottom of the tube. My CEL has finally gone off.. hopefully for good but not from what I read on here with everyone's intakes
Old Jun 1, 2009 | 04:46 PM
knighthawk's Avatar
its fine its the air box delete mod there is actually how toos on the site to do this.
Old Jun 1, 2009 | 04:47 PM
silverguns's Avatar
Awesome! Thank you
Old Jun 1, 2009 | 04:50 PM
UmeNNis's Avatar
Yes, as long as the air is still being filitered, this is actually a hp adder.
I got ~10whp from doing this with a high flow filter
Old Jun 1, 2009 | 04:53 PM
chris88z24's Avatar
I like to feed sand through my air intake while my buddy floors the car, it helps to port and polish the internals of the blower and motor. Works great!
And as long as the MAF is there, check for leaks after the filter. My tube comes undone every few k and throws a code...
Old Jun 1, 2009 | 04:58 PM
silverguns's Avatar
yep sensor is there.. Also there was a nice gash in the plastic tube.. I couldn't tell if was an actual hole but used the K&N "warning" sticker to cover it..
Old Jun 1, 2009 | 04:59 PM
chris88z24's Avatar
ANY air leaks (unmetered air) past the MAF will throw a code... just a heads up
Old Jun 1, 2009 | 05:04 PM
silverguns's Avatar
Thanks guys.. I'm fully relieved now
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
c_m_shooter
Sep 27, 2015 04:40 PM
DocSvensk
Sep 27, 2015 02:24 PM
