no start after cluch install
Old May 18, 2014 | 10:45 AM
justinchinn's Avatar
Exclamation no start after cluch install
just had my car at a local canadian tire to have a clutch and flywheel installed.. after the work being done the car wouldn't start. there is power to everything turn the key and a few clicks come from the engine bay.. after a few attempts the car started but runs like **** and there is a cam sensor voltage message and reduced power message.. any suggesions??
Old May 18, 2014 | 11:16 AM
been doing a bit of research. i had the fidenza flywheel installed. seen some reviews that the lightweight flywheel causes miss fires.. anyone else running a fidenza have this issue?
Old May 18, 2014 | 11:38 AM
tomj77's Avatar
did u check ur battery? it may have power to power everything but not enough to start
Old May 18, 2014 | 11:47 AM
its got power the garage had it on a battery charger to make sure that wasn't the problem.. they got the car to start but it runs like ****
Old May 18, 2014 | 02:03 PM
09outlander's Avatar
Originally Posted by justinchinn
just had my car at a local CANADIAN TIREto have a clutch and flywheel installed.. after the work being done the car wouldn't start. there is power to everything turn the key and a few clicks come from the engine bay.. after a few attempts the car started but runs like **** and there is a cam sensor voltage message and reduced power message.. any suggesions??
^^^Found your problem.
Old May 18, 2014 | 08:44 PM
BLKLS's Avatar
^lol, did they plug everything back in? Did they crush a wife when they bolted the trans back up? Did they out it together wrong?
Old May 19, 2014 | 03:43 AM
kzak104's Avatar
did they undo the ground just above the tranny and forget to connect it?
Old May 19, 2014 | 08:25 AM
blueLNFftw's Avatar
"The car runs, but runs like **** and has a cam sensor message"
Sounds like they werent careful and knocked the cam sensor out of place/broke it.
That repair and reset should be on them.
Old May 19, 2014 | 02:20 PM
thanks for the suggestion.. i've seen a few posts about lightweight flywheels causing idle issues.. think its likely that might be an issue???
Old May 20, 2014 | 03:45 PM
turned out the mechanic didn't plug in one of the connectors for the ecu all the way.. car is up a running.. fidenza flywheel and lsj clutch upgrade are well worth the money.. thanks for all the help and suggestions
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
