Oil covered spark plug
Hey guys, (Long Read) sorry
A few weeks ago I lost all or most of the threads in Cylinder 3?(second one if standing on passenger side) that holds the spark plug
threw P0300 and flashing cel
well i was able to put an old spark plug in temporarily, caught some threads...luckily
ordered new plugs NGK Bkr7e 4644
once I received them I went to install them (gapped .35), 3 go in like normal except that one, doesnt catch
i have my buddy install the Helicoil insert Sav a Thread. he used RTV silicone, drove around the block and then let it sit for 24hrs
so May 15th fixed it 16th drove till this morning 24th when i started it and wrx mod plus P0300
came home from work (drove the monte carlo) and pulled coil pack cover and the boots
spark plug covered in oil and the boot has oil all in it too
the plug was still threaded in but the insert came out when i pulled the plug
sooooo
my question is, is there a seal that could be leaking oil or does it have to do with the spark plug insert silicone not holding and oil bypassing it?
thanks guy
also would seafoaming the car be helpful too
sooooo
thanks guy
If the plug has oil on it, I think it's coming from someplace else and should not have anything to do with your plug fitting. I mean, the combustion chamber is made for burning gas, not oil, and the other end of the plug has your coil on it. Good luck getting to the bottom though.
i think the helicoil was fine just when i pulled the plug it broke loose the silicone but cant mark it off the list
thanks
all i know so far is i need a new spark plug and possibly a new boot
a new valve cover gasket if/when the cover comes off
is the oil on the bottom of the plug where it sits in the cumbustion chamber..... or on the upper part of the plug where it plugs into the coil?
If oil is just getting on the top of the plug and in the tube itself... could just be the tube seal on the VC thats leaking.... if your leaking oil in the cumbustion chamber though.... thats a whole different deal... possibly rings or valve seals.
Unless you have a severe blowby issue(would hydrolock before oil blew past the plug threads) The valve cover gasket is leaking...like 20$ and takes 10 minutes to fix.
The helicoil coming out...ya, Ive done it to a 5.4 3valve but no other vehicles...Personally, I would throw a head on before I would throw a helicoil on my personal vehicle.
im going to take it into a shop and have them look at it and check out some other components while their at it
I appreciate the feedback and comments guys
just gathering some parts, waiting on a gasket to come in
havent pulled the valve cover yet haha
once all the stuff comes in my buddy is going to come out and do a compression test and we are going to fix the the insert, make sure to do it right and install the valve cover gasket and the seals that come with it
if that inst the fix we will look deeper
ITS ALIVE!!!!! BAHAHAHHA YES YES BABAAAHAHHA
was leaking at the seal for #2 chamber spot, replaced the valve cover gasket and the seals for each coil pack area
ill check it in a few days to make sure its dry still
