oil leak or fuel leak by filter area????
I just took my car to the dealer to get this problem fixed about a week ago :( for the same problem. Had it there for 2 days and it was fixed fine but a week later i decided to check my engine and it had the same leak as before.
I don't know if i should take it back, car is under warranty and it only has 30k miles mind you this is a 2009 cobalt ss turbocharged. according to the invoice they replaced a gasket by the fuel pump and put some sealant around the area. I believe it to have worked because i checked it like 3 days after the repair and it was nice and clean except today, which makes it a week later.. anyway i decided to check under my hood because something weird happened today. I went from shifting to 2nd to third and for some reason my rpms shot up to the redline for like 2 seconds for no reason, and i wasnt even giving it gas and i put it in neutral and everything. Anyways thank god nothings messed up, car still runs fine, all you hear is that noise direct injection.. well thoughts, opinions and advice would be greatly appreciated thank you. |
Sure it isnt residual from the repair?
(Post 7269906)
Sure it isn't residual from the repair?
The three most likely places are the high pressure fuel pump, intake cam position sensor, and intake cam cap. Mine was seeping oil from all three and it will make it's way down to the oil filter.
So its just a small leak by the fuel pump so i shouldnt be concerned since the dealer cant fix it ? Great how to though.
Originally Posted by 1Panel2NV
(Post 7269911)
Soo any long terms of not having this issue fixed?? Lets say 6 months to a year with this problem?? Anyone go on longer with this problem.. your input is greatly appreciated.
Originally Posted by Diaz1488
(Post 7270290)
https://farm6.staticflickr.com/5482/...7a343e68_c.jpg |
even with a lnf engine bay clean from dirt, still looks like a mess of shit going everywhere :P
