oil leak or fuel leak by filter area????
Old Feb 10, 2014 | 08:27 AM
Diaz1488's Avatar
I just took my car to the dealer to get this problem fixed about a week ago for the same problem. Had it there for 2 days and it was fixed fine but a week later i decided to check my engine and it had the same leak as before.
I don't know if i should take it back, car is under warranty and it only has 30k miles mind you this is a 2009 cobalt ss turbocharged.
according to the invoice they replaced a gasket by the fuel pump and put some sealant around the area. I believe it to have worked because i checked it like 3 days after the repair and it was nice and clean except today, which makes it a week later..
anyway i decided to check under my hood because something weird happened today. I went from shifting to 2nd to third and for some reason my rpms shot up to the redline for like 2 seconds for no reason, and i wasnt even giving it gas and i put it in neutral and everything. Anyways thank god nothings messed up, car still runs fine, all you hear is that noise direct injection.. well thoughts, opinions and advice would be greatly appreciated thank you.
Old Feb 10, 2014 | 08:30 AM
Diaz1488's Avatar
20140210_080053_zpssamxnikz.jpg Photo by diaz14881 | Photobucket
Old Feb 10, 2014 | 08:32 AM
blueLNFftw's Avatar
Sure it isnt residual from the repair?
Old Feb 10, 2014 | 08:34 AM
Grave's Avatar
https://www.cobaltss.net/forums/how-...-leaks-189081/
Old Feb 10, 2014 | 08:35 AM
Diaz1488's Avatar
Sure it isn't residual from the repair?
I doubt it, first 3 days was clean as day. Now its leaking in the same place. Hope my link worked so you can see the leak by the oil filter. Im sure residual from the cleanup doesn't look like that
Old Feb 10, 2014 | 08:39 AM
Grave's Avatar
The three most likely places are the high pressure fuel pump, intake cam position sensor, and intake cam cap. Mine was seeping oil from all three and it will make it's way down to the oil filter.
Old Feb 10, 2014 | 08:42 AM
Diaz1488's Avatar
So its just a small leak by the fuel pump so i shouldnt be concerned since the dealer cant fix it ? Great how to though.
Old Feb 10, 2014 | 08:43 AM
Diaz1488's Avatar
I see thanks, i knew i wasnt the only one with this issue i will head back to the dealer first thing in the morning tommorow.
Old Feb 10, 2014 | 02:55 PM
Diaz1488's Avatar
Soo any long terms of not having this issue fixed?? Lets say 6 months to a year with this problem?? Anyone go on longer with this problem.. your input is greatly appreciated.
Old Feb 10, 2014 | 04:18 PM
Grave's Avatar
Ummm...messy engine bay. It's not that hard to fix the leaks. I like a clean bay though.
Old Feb 10, 2014 | 04:30 PM
kzak104's Avatar
even with a lnf engine bay clean from dirt, still looks like a mess of **** going everywhere :P
06MetallicBalt
Jul 20, 2025 08:47 PM
biniecki
Oct 25, 2015 02:23 PM
no_ss
Oct 18, 2015 11:58 PM
Trav3480
Oct 1, 2015 08:17 PM
Stuff
Oct 1, 2015 05:47 PM
