oil on pistons
oil on pistons
i have a lsj which i just rebuilt with brand new everything pistons,(diamond racing), new rings, cometic headgasket and arps and the head got redone. everything and the car is on boost and i changed the turbo thinking it was bad because it was smoking and i put a brand new turbo on it and it didnt smoke drove it around for a little and no smoke. parked and till next day and went to drive and and it starting smoking everytime i give it a lil gas,so i take out my plugs and and look down into the cylinders and the pistons are wet with oil all four. did a compression check and its perfect 180-210. and the oil problems isnt the turbo. anyone have any idea what it could be? motor has like 2000 miles and 1000 were break in and i really havnt gone wot on the car because i need to tune
what do you have for an oiling set up? more info about swapping the turbo? what turbo ? brand new?
what do the plugs look like? is the car running ok, or is there any issues? who rebuilt the motor? did this happen before the rebuild aswell? what ring gap are you running? did you hone the cylinder walls or have them machined or do nothing?
trying to narrow down your problem
hey guys. i have been racking my brain trying to figure this out as well. i am his tuner. here is what i have concluded so far.
-no oil in charge pipes
-no pcv valve but the car has breather mods
-holds compression test well
it is on a gt35r dual ball bearing turbo
one more thing i am thinking of. richard do you have an oil restrictor on the oil feed line?
Asked but never answered "does it smell like burn oil"? Just making sure it is "oil"
oil return drains into a tank and then i have a electric pump that pumps it out of the tank up into the the filler cap.(turbo mani i have sits my gt35r to low and cant get a good drain into the oil pan, so i did a setup for the return like if i had a rear mount turbo) so idk if the oil problem has to do something with the oil going back into the motor threw the cap on the valve cover?
i understand that but the car was running fine before. all 4 cylinders going bad at once is just too random.
True that... weird that the CP is dry from oil...
Last edited by TurboTechRacing; Dec 12, 2010 at 09:25 PM. Reason: Automerged Doublepost
first how do you know its not the turbo, second if compression is good then its not the rings, now if he gets all the oil out and the cylinders look like this 180-210-210-180 id say has a leaking valve maybe the valve stem seal is bad, if you do a leakdown test how long does compression stay and what does it read. do this if you can take the turbo off the manifold and run the car like this, and take the oild fed line and plug it up. to verify the turbo is not the issue. or u can just look at the seals. wut i would do is leak down test , and a 5 stroke compression test. when warm. Also check your inducer side turbine for oil. maybe you have a lot of blow by.
and lets say i turn on the car and let it idle there for like 1hr it wont smoke at all, i tap the throttle and a little cloud of smoke comes out and stops until i tap the throttle again
i jsut wrote this while all you guys were done writing your all post so dont hate... lol... blazin you said you tued him, whats his afrs at idle. in boost, and how much boost. remember this as well if you broke a rigland your compression can read good, but while driving the res go much much higher and turn the rings into sliding doors into the sleeves, so a compressin test will not really find a bad piston ring/ ring. id do a leakdown test.
but weird is that all 4 pistons are wet with oil and the turbo is clean, no sign of oil on it.
but dam for all valve seals to go back to get oil in all four cyclinders??
yes and yes
ok so we can prolly elliminate the motorbuild as being the culprite
are you running a restrictor on the turbo feed line? you shouldnt be since the garret ball bearing turbos have them internal
no joke but to me sounds like turbo seals bro, all 4 cylinders will not go bad at the same point, if it had to do with the engine i could see the valve stem seals being bad but that would men it would have been bad from the start. Or your head gasket is bad in all cylinders which sounds unlikely. letting all the oil galleys open to the cylinder. do you have a lot fo blowby.
did you assemble the motor yourself? lining up the rings and oil rings in the proper sequence?? you cant just slap them in, they should be something like 30 degreess offset from the main ring which should sit facing the rear of the cylinder wall, and what gap did you file them too? dont want to see more then a .50 gap, should shot for .30 to .35
turbo has no more then 30 miles on it and all inter cooler piping and intake mani are oil free
compression check will test out how much pressure is inside the cylinder but will not test how long its there, so check it by doing a leakdown test.... if there is no oil in any piping then 1 its not the turbo unless the turbo is spooling to much boost for the engine and will cause alot of blowby, but as stated before theres no oil in piping, so either valve stem seals or ringlands. in between the sleeves is coolant so we know its not the sleeve.
