One headlight is dimmer than the other...
I have a question. I have noticed a headlight that was more dim than the other (the passenger side was dimmer) so I replaced it with a pair of Silverstar Ultra's. So as soon as I get it replaced I look to see if the problem was solved and nope, the stupid this is still more dim than the driver's side. The headlight isn't crooked, just more dim. Suggestions?
any other thoughts?
I'm too JDM for you
yes, while i was assembling the lights i checked the mounting brackets. i also walked around the cars front end from a distance to see if i could find a bright spot, but also came up empty handed and then finally, the beams are not off. i was leaning toward the resistance theory too actually.
yeah, that must be it.
its dark out now...drive up to a dead even wall. park 20 feet away and make sure they are aimed properly. adjust with the allen head bolt on top of the headlight
well, i'm having a hard time with the allen because i don't have the right size. grrr. but i believe that might be it. you have to get really low to the ground, but if you do you see the passenger side brighten up a lot. i'll try more in the morning when i can see better.
