ONGOING Problem- Could be an easy fix!! PLEASE HELP
Old May 2, 2007 | 01:49 AM
SSinPhilly's Avatar
If your not getting fluid out of the slave when you push the clutch pedal, the clutch will not disengage. When you go to start the car, its going to want to launch forward if its in gear. If its in neutral, you will be able to start it, but you wont be able to get it into gear. Continue bleeding the clutch line til you have fluid coming out of it. Keep the master topped up. It is possible that you have caused a leak in the slave and thats why your not getting fluid.
This is the problem I have i found the above in another post and its my exact sympthoms that comes and gos periodically. Along with this anytime i get on the car the littlest bit the clutch pedal dissapears. I have to restart the car to get the pedal back if not the clutch will grind b/c i will have barely any pedal to up or down shift.
I think i need to bled the clutch but i wanted a second opinion. I got a stage 2 clutch installed and had problems 3 months after til now.
I would appreciate all your help!
Old May 2, 2007 | 06:15 PM
SSinPhilly's Avatar
someone please help me out im going on a 1200 mile trip in 2 days- thanks guys
Solaris99
28
Mar 15, 2017 01:22 PM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
