Overcharging Issue on Turbo Swap
Old Jun 4, 2012 | 11:45 PM
brideout_8's Avatar
I turbo swapped my cobalt and now have run into a what appears to be an overcharging issue. I am dyno tuned on 24psi. I bought the complete turbo swap from zzp. When I get to about 10psi my dash lights, HVAC, and headlights start to get brighter. They continue to get brighter until they shut off. My dash goes completely dead. But the car still pulls its ass off. As soon as I let off everything comes back on like normal. I also get the ABS light and power steering message. Both go away instantly also. When I disconnect my alternator the problems goes away. I bought a new alt from zzp and swapped it out but still have the same issue. I also hear static in my speakers now. I replaced the ground wire on my battery and found where two sets of wires are ground under my dash. There are black marks at that particular ground. So I split them up to better grounds but still have the same issue. Is my problem my alternator and just happened to get two bad ones or is there another problem with my wiring?
Old Jun 4, 2012 | 11:57 PM
brycerice13's Avatar
something is grounding out. Check to see if you have any wires that look exposed or if you have a stereo that has a amp that is not grounded correctly or something like that.
Old Jun 5, 2012 | 12:01 AM
brideout_8's Avatar
I do have an aftermarket head unit that was installed by BestBuy. I will try to find that ground. Would a bad ground on my radio affect my lights and my dash?
Old Jun 5, 2012 | 12:23 AM
ItalianJoe1's Avatar
Yeah, because the radio and all that stuff is wired into the BCM.
What do they do for the backwards-spinning issue on the alternator?
Last edited by ItalianJoe1; Jun 5, 2012 at 12:23 AM. Reason: Automerged Doublepost
Old Jun 5, 2012 | 12:32 AM
brideout_8's Avatar
They send you a completely different alternator. I believe it is a 2.2 with the lsj wiring connector. So great I get to tear apart my dash tomorrow to find this little point that is not right.
Old Jun 5, 2012 | 12:35 AM
Dart_SI's Avatar
sounds like your going faster than the speed of light to me.
Old Jun 5, 2012 | 12:39 AM
BLAZIN07SS's Avatar
I'm too JDM for you
It's a solstice/sky alternator if I remember correctly.
Old Jun 5, 2012 | 08:37 AM
brideout_8's Avatar
Ha your not the first one to tell me that. I would believe that but my radio stays on! Unless that light travels faster
Old Sep 6, 2012 | 07:31 PM
brideout_8's Avatar
To give an update and fix to this problem for anyone who might have similar issues later... today after going through countless things for about 3 months I found something while searching on the internet to make me think my spark plugs might be the issue. So I pulled them and researched them to find out that they are non resistor plugs.(Tuner changed them) I went and got the plugs that came with the kit and poof all my problems are gone. Now I just have to find the appropriate gap and I will finally have the car I have always thought I would since May when I did the turbo swap.
Hope this helps someone down the road.
Old Sep 6, 2012 | 07:40 PM
YelloEye's Avatar
WTF that's really odd. But glad you got it.
Turbo Johnny
Feb 21, 2019 09:41 AM
bigdeertz
Nov 17, 2016 09:41 AM
CarbonFiberCobalt
Mar 16, 2016 02:51 AM
CobaltSS 16
Sep 29, 2015 01:53 PM
