P0036 / p0037
P0036 / p0037
P0037 is a low voltage to Ho2s downstream and 0036 I believe is for a fuse on the same sensor. I replaced the sensor, but still getting codes. Does anyone know where the fuse is for this sensor? I checked the engine and the interior boxes, but none of the descriptions mention this sensor.
Also, can being catless cause these codes to pop? I thought catless would only bring about the usual P0420. Have to get through emissions soon, and just want to double check before I throw the stock pipe back on, as it's a PITA to get to those bolts.
Unfortunately there are is no fuse labeled EMS at all. Here are the 10A fuses under the hood -
DRL
Horn
SDM
CNSTR Vent
A/C Clutch
CHMSL
ABS2
BCK Up
RT hi beam
RT lo beam
LT hi beam
LT lo beam
EXH
ENG VLV SOL
AIR SOL
PRK Lamp
DRL
Horn
SDM
CNSTR Vent
A/C Clutch
CHMSL
ABS2
BCK Up
RT hi beam
RT lo beam
LT hi beam
LT lo beam
EXH
ENG VLV SOL
AIR SOL
PRK Lamp
