p0107 and p0122 need some help THANKS :)!!!!!
Old Jun 12, 2011 | 03:30 PM
Dragonsfire12345's Avatar
Ok so I haven't posted this on here but I swapped from being sc to tc. I swapped a guy here in SA for a precision 5557 turbo setup. We swapped literally everything for everything. Even the map sensor and throttle body, which I wish I should've kept mine. Now I'm throwing codes p0107 which is for the map and a p0122 which is for the tb position sensor/ switch a low circuit input. I removed the map sensor and it has alot of oil on it, can I clean it with maf sensor cleaner? As for the p0122 code I checked my wiring to see if I might have pulled it loose but it looks to be solid. Anymore ideas on what could be causing this?
Old Jun 12, 2011 | 03:35 PM
07BoostedG5's Avatar
You can try to clean it but really you need a new map now.
As for the TB if your wiring is in check it may me a bad TB, I would replace the Map 1st then clear the codes and go from there.
And you need a catch can, your getting blow by or a leak, moneys on blow by thou.
I would also check the butteryfly valve on the TB and make sure oil hasn't gummed it up awswell.
Old Jun 12, 2011 | 03:37 PM
damn I should've kept my map then.... >
Old Jun 12, 2011 | 03:51 PM
It has a catch can
Old Jun 12, 2011 | 05:01 PM
ok, I cleaned up the map sensor just to see if it will hopefully work, also cleaned the throttle body as well. Lets hope it work!!!
Old Jun 12, 2011 | 05:09 PM
good luck man!
Old Jun 12, 2011 | 08:49 PM
ok so update, I cleared the codes with my trifecta cable. Turned the car on for a little while and seems like the codes didn't come back. Hopefully it stays like that!!! We shall see(cross fingers)
Old Jun 12, 2011 | 09:30 PM
cool, I figured the map may through a false tb code (I have had that happen before) or it was a gummy butterfly valve.
Old Jun 12, 2011 | 09:36 PM
the tb was extremely dirty, I sprayed it til clear liquid rolled off.
WopOnTour
Jan 22, 2015 02:08 PM
Balto82
Sep 21, 2014 04:28 AM
Billig ss/sc
Jan 6, 2014 10:03 PM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
