P0141
Old Dec 8, 2008 | 07:37 PM
bbbevans89's Avatar
P0141
My Car Is Now Throwing A P0141 And I Would Like For Someone To Help Me Solve The Problem Ive Replaced The Downstream 02 Sensor Already After I Installed A Downpipe I Also Have Aluminum Wrap Around My Sensor Wires And A Little Bit Of The Sensor Will This Cause A Code Thanks.
Old Dec 8, 2008 | 10:03 PM
thecobaltguy's Avatar
my best bet is go to a dealer and as them what the code is.....
Old Dec 9, 2008 | 05:52 AM
bbbevans89's Avatar
i no what the code is lol i just dont know what else to do to trouble shoot its something like 02 heater malfunction bank 1 sensor 2
Old Dec 9, 2008 | 03:22 PM
bbbevans89's Avatar
help lol
Old Dec 9, 2008 | 03:47 PM
light'bolt's Avatar
catless down pipe? Is this the sensor behind the cat?
Old Dec 9, 2008 | 03:48 PM
bbbevans89's Avatar
i have a catted downpipe and yes its the sensor behind the cat i also replaced the 02 sensor.
Old Dec 9, 2008 | 03:50 PM
Edubs's Avatar
Did you extend/rewire the sensor yourself or is it the stock sensor unmolested?
Old Dec 9, 2008 | 04:08 PM
bbbevans89's Avatar
no rewireing stock direct connect from bosch
i did break the piece that connects my o2 sensor to the frame but it still connects great it just a little push piece to hold the connector on the bar.
Old Dec 9, 2008 | 04:09 PM
Edubs's Avatar
If you're not having any driveability symptoms from this, it is most likely just the high-flow cat. Anyone w/ HPT can turn the MIL off from that scenario...
That plastic clip has no effect on the sensor's performance.
Old Dec 9, 2008 | 04:10 PM
bbbevans89's Avatar
yea i know would a 02 sensor cel eleminator work my problem is i dont no anyone on maryland that can do this for me .
Old Dec 9, 2008 | 04:12 PM
Edubs's Avatar
Look for someone to just tune it out. You're not the only person in Maryland that owns a GM or Ford...
...start by looking in the regional section on here for someone w/ HPT.
Tuning section has a list of people that you could contact to have that addressed.
https://www.cobaltss.net/forums/tuning-131/available-tuners-locations-86603/
Here's an active thread w/ MD members talking about a meet in the Spring. Pop in there and ask if they know of any local people w/ HPT:
https://www.cobaltss.net/forums/show...24#post3186124
Old Dec 9, 2008 | 04:29 PM
light'bolt's Avatar
don't know how those work but if it fools the computer into thinking you sensor is ok then it should work. The CEL should go away after it doesn't sense the error after a few cycles.
bryanbassett
May 18, 2015 12:00 PM
johnladow07
Oct 11, 2010 09:47 PM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
