p0300 and plug issue
please i need help by the knowledgable fellas on this site. I've been sputtering bad at random times at around 4K'ish. Feels like it hits a brick wall, and doesn wanna move.. I usually let off, right when it happens, so maybe if i kept my foot down it would go into limpmode or something, but anyways. I jsut got the car back from the exedy clutch install and its happened two days in a row now, then I threw a p0300 that night. The plugs I have in there are brand new, and they are gapped at .035. My mods are 2.9, DP, gmpp exhaust, and a 90 shot. I havent sprayed on these plugs yet, but then again this isnt the first time this has happened. What plugs should I run, and what should I gap them at??
What is the problem?? could it be a blown piston or something??? I really have no clue, and I'm scared to give the car some gas, because I dont wanna blow something up. Any help would be appreciated.
Thanks (if you have any questions feel free to ask)
Chris
help ppl plese
Chris
help ppl plese
Last edited by 04redline0124; Jun 4, 2008 at 07:39 PM. Reason: Automerged Doublepost
Pull the damn plugs and check them like I told you. Re-gap them smaller, and see if it helps. Or, get a different brand of plugs like I told you a long time ago. Your car was fine for me over 100 miles of driving on Sat night, so I dunno. Driver mod?
how can i test that thoe??
Last edited by 04redline0124; Jun 4, 2008 at 07:52 PM. Reason: Automerged Doublepost
omg seriously dude, its got nothing to do with the driver, I pulled the coils to see if any of the plugs came out with them, and to see if there was any oil. The code was a p0300, and Im hoping my motor is blown, because I can't take this anymore. Not knowing what is wrong its pissiing me off..It;s either the injectors, pistons, cams, crank sensor, spark plugs, or coil pack connections. Anything we can do on HP tuners??? I really need to do this compression test man, and then maybe a leak down test I dunno
HPT can't fix the problem. P0300 is a general misfire code, which we know is happening. Why would the plugs come out with the coils? Pull the plugs and check them, clean and re-gap them to a smaller gap, and see if it helps. Its not pistons, its not cams. Crank sensor won't give misfire codes in most cases, but will totally shut the engine off. Happened to me. Check the plugs, thats where the problem is. I don't know about the coils, they seem to be fine, since its so random, but its always a possibility. Did you ever reconnect the boost line you have plugged?
havent reconeccted it no. We shall see when we do the compression test. It has to be something man, and is there a way to test the connections to the coils with your meter??? That could help i guess. I just wanna figure it out, so I can go on with my moding life!! I wanted u to check something on HPT with that sprak table **** or whatever.. I would tell if im misfiring at idle, and I wann check for knock and ****
If you did have a piston problem, it still wouldn't do what you are saying. My car doesn't, and I know I have a demolished compression ring/land on one piston.
Check all the wires going to the coils to ensure they haven't been pinched or cut. Check all the electrical connectors in/around that area as well since the clutch job was just done in case something was missed by accident. Finally clear the code and run out that tank of gas and replace with some good 93 octane. If none of that works, then you might need to replace the coils. I've only seen a couple cases where the coils have died on here, but it's a possibility.
update!!! it wasnt the gas, because it happened againafter i drained it out and added new gas. I put in injecotor cleaner and Seafoam into the car to see if i could clean the injectors and see. I have new plugs also that im gunna put in in a second, so all that is left that ican think of if it happens again, would be the coil packs. We did a compression test and it read 210 210 200 200 so those are good. Anything could help guys thanks!!!
o and also it doesnt happen in 3rd ever lol..jsut every once in a while in 2nd. Could it be the tune?? bad pcm? bad MAF?? It feels like fuel cut lol!! that is all the desciption I can give.
Chris
Chris
Chris
Chris
My question.....Do you still have a CAT on the car? When those clog they make the car run like crap under boost exactly as you are describing.
Last edited by Psykostevo; Jun 10, 2008 at 05:45 PM. Reason: Automerged Doublepost
nope I am catless, and yes I have an intake.. its a k&n..and i've never cleaned my MAF, but as stated it happens at totally random times, liek it could be fine and hten all of a sudden **** up. But recently its been happening alot. My buddy swears its fuel cut, but what on earth could be causing fuel cut??? And I wanna pull my injectors, but what would i be looking for once pulled?? I have no knock thoe. We logged it and there is never knock, unless it also happens at random times, and then it screws up the car.
Running rich would cause no knock, but other funky problems.
but my plugs suggest that it is running lean, because they are white... i need a Wideband bad lol..
His tune is pretty much GM S2, as far as fuel cals are concerned. The only thing is timing is backed out under power, to allow for the 90 shot.
Im hoping it was a bad plug to begin with, and the other times I fouled the plugs out because of spraying
So many things, but based on what you are saying (and have already eliminated) a far as misfire under load and setting a P0300...
-Replace your plugs with NEW stock plugs gapped at 0.035"
-Carefully inspect the plug boots to make sure you dont see and scorching from arc-throughs
- try unplugging your CAM sensor temprarily to see if the misfire is still present (you will get a MIL and a DTC but it will operate in a backup/failsafe mode)If the cam sensor is incorrectly timed (was it removed?) it can cause the condition you describe
- Make sure all your injector connectors are all correctly installed. Sometimes the the injector harness can be put on backwards and this will put the injectors out of the correct sequence. Besides the pink/blk 12V+ wire going to each injector the other wire colors are as follows:
#1 should be BLK
#2 should be LT GRN/BLK
#3 should be PNK/BLK (both)
#4 should be LT BLU/BLK
If that all looks OK then...
The crank sensor is the primary input used to detect a misfire, so a bad crank sensor CAN cause a misfire and CAN set a false P0300 series DTCs.Now I dont mean FAILED CKP (which would cause a no start) but issues with the signal quality itself. Unplug it and inspect the CKP connector and make sure it's not damaged or corroded. Sometimes the CKP sensor can take on oil which contaminates it's windings and create a misfire at certain frequencies. Since the CKP is not very expensive, the easiest thing to do is bang one in.
HTH
WopOnTour
#1 should be BLK
HTH
WopOnTour
#1 should be BLK
HTH
WopOnTour
#1 should be BLK
HTH
WopOnTour
#1 should be BLK
HTH
WopOnTour
#1 should be BLK
HTH
WopOnTour
I guess the CKP sensor would be a possible thing, I did have to replace mine, but my car used to shut down under power, did it like 3 times over a couple months. Still not really what he's having, but like you said cheap idea to try.
thanks man ill have a buddy check that sensor for me to see if its corroded..that might sound like its the problem...i mean 3rd gear it never happens, unless the plugs are completely fouled (which it has happened once before)...where this might be located thoe (the CKP sensor, and the CAM sensor)?? maybe i can take a look....im really hoping its not the coil packs, since they are alittle expensive lol
Last edited by ItalianJoe1; Jun 10, 2008 at 08:41 PM. Reason: Automerged Doublepost
Same NGK BKR7E's that hes been running for a long time. Well, a new set, but the same type.
Last edited by ItalianJoe1; Jun 10, 2008 at 08:45 PM. Reason: Automerged Doublepost
Gap is good at .035, im running .040 myself on the same plugs.
Since its happened before it could be a coil pack(s)
This has happened on other cars.
