P0449 code help
I have a CEL and it shows a code of P0449. What is the issue and what are the repair procedures?
any help? |
i dunno what it is. but i bet you there is about 100 threads on it already
Evap purge solinoid....easy to change right in the engine bay. Do you have a TB spacer?
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
my TB is stock
thanks for the replies. Any idea where the solinoid is? |
any help guys on how to fix this? P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
Anyone have a pic where the vent solinoid is located onthe canaster.
took my code reader and deleted my p0449 code but it comes back a few minutes later. Says Evaporative Emission System Vent Control Circuit Intermittent. i am going to check for a loose connection but if i don't find one should i just replace the solinoid?
Originally Posted by SSinPA
(Post 4545713)
don't know but trust me my gas cap is tight. CEL has been on over a month now.
Heres the pic you are looking for.
Very easy to replace.
http://i171.photobucket.com/albums/u...lt/1387197.gif Sorrry thats the purge selnoid heres what you need http://i171.photobucket.com/albums/u...lt/1651435.gif |
So replacing should fix the CEL?
(Post 4547158)
There also could be a wire broken or shorted ,Did you check the connections to make sure they were okay? The solenoid is located at the back of the car,if you dont hear the trunk monkey banging anymore then there is something definitly wrong with the evap cannister vent solenoid or its wires or connections. |
Come to think of it I haven't heard those pesky monkeys lately. Thanks a bunch.
Will a bad evaporate purge solinoid cause por fuel economy?
(Post 4551377)
the gas evaporating and escaping through the open valve.But not a 100% on that. |
HEY HEY HEY!!!! Check the fuse in the underhood fuse panel first. My blew after doing a 2nd gear burnout one night and made my car go crazy. Check the emissions fuse FIRST.
Thanks I'll check that. Never even occured to me. All the damn electronics on our cars I'm surprised the aren't radio controlled.
ok I'm back with this same damn code that has been on for months. Both the evap and purge solinoids have been replaced, fuses checked and good, and from what i can see the wires and connections are good to the evap soliniod. Still no trunk monkeys and the code keeps returning after erasing. Any suggestions?
any one? |
Same boat.... Any ideas?
Did you fix it?
Originally Posted by Coblasts
(Post 4547324)
If that is what the problem is (valve not oppening or closing when commanded to)
There also could be a wire broken or shorted ,Did you check the connections to make sure they were okay? The solenoid is located at the back of the car,if you dont hear the trunk monkey banging anymore then there is something definitly wrong with the evap cannister vent solenoid or its wires or connections. What are these "Trunk Monkeys" you speak of ??? I just bought an 06 SS and have code P0449. I prefer to troubleshoot problems instead of just throwing parts at it so I'm reading up on it. Is the solenoid supposed to make noises when the ignition is turned on or off or what? I haven't heard any sounds coming from the rear of the car. Thanks in advance for any help. |
Fixed my problem. Found wiring harness chewed up by a critter in the back right by the cannister. Respliced and all good. Still don't hear any trunk monkeys?????
