P0606+P2101 trouble...
so Ima give yall the whole story so nuthin is missed.....
a couple days ago, it started when my balt woud sound weak when I crank it up, like the battery was goin or somethin.
2 days ago, i had to get a jump to get to work.. last night, I had to get a jump 2..
So TODAY, I had lunch at noon, put my battery on the slow charger an let it sit til I got off(6pm)
at 6, I put everything in, turned the key to on, no problems so far... tried to start.. *click* nuthing... next time.. *click* nuthin....
the third time it clicked.. sat for bout a second an then started up, but it sounded like ****, Eng pwr reduced etc displayed, an I had a CEL.. an the engine was lopin like it had cams or somethin, kept bouncin between 8k an around 1.5k rpms, i give it a lil gas, an it reacts.. but then goes back to soundin rough, I shut it off...
start it back up an it sounds fine.. like it never happened, but I still got the CEL.. got the codes read an it showed a P2101(Control module Throttle actuator position performance error) and a P0606(ECM internal performance error)
I started drivin, got to the gas station about 500 meters away to get some smokes.. got back in, started it up, an it was back to the same ****, lopin an ****..
cut it off, back on, no problem...
on the drive home, I didn't notice anything crazy happening.. other than at idle, the balt sounded extra quiet, an my bpv didn't seem as loud(or maybe I was jus paranoid lol) and at idle(or my foot on the clutch) my gauge read 20hg in vacuum, which seemed a lil high..
also, it seemed like it backfired a lot goin from 1st to second...
Can anybody help me with this?? I'm not really in a position to be throwin parts at the balt to see wat'll happen :\
if it helps, I got an 09 SS w/ an intake,dp,chargepipes, Forge bpv, an trifecta tune...
I gave it a look over earlier an didn't see anything obviously wrong/broken.. but Ima dig in a lil more later on an see if I can find somethin..
Last edited by MastaShaKe_88; Jun 8, 2012 at 08:54 PM. Reason: Automerged Doublepost
bump?
lil update, I went out an my car started fine, but still showin a CEL
Last edited by MastaShaKe_88; Jun 8, 2012 at 10:47 PM. Reason: Automerged Doublepost
Last edited by MastaShaKe_88; Jun 9, 2012 at 12:23 PM. Reason: Automerged Doublepost
