Performance problems
Old Nov 10, 2012 | 03:13 PM
07cobaltss\sc's Avatar
I have a 07 supercharged cobalt. First off I have an Aem cold air intake, and a exhaust muffler.
Now to my problem. Every gear I'm in when I'm cruising down the road and punch the gas the rpms shoot up but my car doesn't get up and go. For example if I am in 3rd gear and punch the gas rpms will shoot up to 6000 rpms and then back down to 3000 or 4000 rpms before the car will take off. I've heard it could be a boost leak but I'm not real sure. Any help would be great.
Thanks!
Posted from Cobaltss.net App for Android
Old Nov 10, 2012 | 03:22 PM
K-Train04RL's Avatar
Sounds like a fried clutch possibly
Old Nov 10, 2012 | 03:27 PM
either clutch slip or belt slip. probably clutch. when you do this do you smell something burning afterward?
Old Nov 10, 2012 | 03:43 PM
Vander Nars's Avatar
fried clutch this was how my car was when i bought it, replaced clutch asap and all was good.
Old Nov 10, 2012 | 03:44 PM
Bass_Waves's Avatar
do you get a smell in cab when this happens?
Old Nov 10, 2012 | 03:55 PM
prevsrt4owner's Avatar
Slipping clutch, m8te.
Old Nov 10, 2012 | 06:44 PM
sLAsh's Avatar
Sorry to pile on but you definitely need a new clutch
Old Nov 10, 2012 | 06:59 PM
mexi_loco's Avatar
a slipping belt would also produce the same symptoms as a slipping clutch. best way to tell if the clutch is gone is to drop it to fifth from first. If nothing happens, it's the clutch. If the car stalls violently....it's not the clutch, and most likely a belt issue.
Have you done anything to the supercharger or the engine that has required you to remove the belt? How many miles is on the vehicle?
Old Nov 10, 2012 | 07:18 PM
BLKLS's Avatar
This is probably the worst advice I have ever heard. If you want to chance over revving your engine go ahead and do this.
Old Nov 10, 2012 | 07:37 PM
bratboy90's Avatar
Belt slipping does not create the same issue... WOW...
It's clutch...If rpms raise without car moving it's always clutch, NEVER belt. Now if if rpms are steady, but boost gauge bounces, that's belt.
Old Nov 10, 2012 | 07:39 PM
TurboTechRacing's Avatar
Sounds like you need a KY brand clutch kit, we carry.
Old Nov 10, 2012 | 07:40 PM
NOT a slipping belt. However, there is some type of KY brand clutch that this one guy sells.
Old Nov 10, 2012 | 07:52 PM
mexi_loco's Avatar
really....that would be news to my buddy that actually had the same symptoms, thought it was his clutch, and it turned out to be his belt slipping. I guess you're right, I really shouldn't recommend dumping the clutch like that. There's better ways, but that is one way. And I believe he did mention he was sporadically going into high boost as well.
edit: just read it again, doesn't mention anything about boost. but i'm sure that would also be some information to note.
Old Nov 10, 2012 | 07:57 PM
That would be us www.TurboTechRacing.com
Old Nov 10, 2012 | 07:59 PM
mexi_loco's Avatar
nooo......it would be the OTHER guy from TTR....gawd aaron! why do you think we're always talking about you?!
Old Nov 10, 2012 | 08:07 PM
insylem's Avatar
Thanks!
Clutch
Old Nov 10, 2012 | 08:48 PM
Lol's
Old Nov 10, 2012 | 09:16 PM
insylem's Avatar
Question
I don't understand how, please do explaine.
Old Nov 11, 2012 | 12:31 AM
sLAsh's Avatar
He can't explain cause he is wrong. Belt can't cause these symptoms, only a clutch or spinning tires can. Since op says it does it in all gears and I doubt he has enough power to spin the tires in 5th it has to be a clutch.
Old Nov 11, 2012 | 12:58 AM
insylem's Avatar
I know, that was my way of basicly trolling him about it. Besides, it wuld have been great Lulz to see what he would have came up with
Old Nov 20, 2012 | 11:14 PM
Ph3lix_004's Avatar
Looks like i need a new clutch....
Old Dec 27, 2012 | 11:25 AM
Grover211's Avatar
I just started having this problem a few days ago, finally found an answer. Yay. Also crap I don't wanna change my clutch.
Old Dec 27, 2012 | 11:33 AM
X1,000,000 for slipping clutch.
Old Dec 27, 2012 | 11:53 AM
Speed_Thrills's Avatar
Definitely don't drop from 5th to 1st... That's a good way to stick your rockers.
Old Dec 27, 2012 | 12:09 PM
Melon's Avatar
definitely sounds like clutch. to defend mexi, not that i agree with him. but he said go from 1st to 5th. not the other way around
