Poor fuel mileage
Old Dec 22, 2014 | 02:37 PM
G85 SS's Avatar
If your ltft is that high, then your short terms are most likely hitting double digits quite often since that number is just an average over time.
Again, I'd be surprised if there's no code.
Old Dec 22, 2014 | 02:45 PM
Speed_Thrills's Avatar
Originally Posted by Shanedude
Yeah 23mpg is not right bro. Unless you're idling that car like mad in drive-thru's and traffic.
What type of tires you running and are they in good condition and at proper PSI?
Spark plugs? You're approaching gm recommended 160,000km change. (I've change mine every 75,000km cheap investment)
Last Oil change? Fresh oil can make a noticeable difference.
Driven with that zzp tune in winter before? Could just be geared towards making more power.
When have you last reset your fuel estimate? I always reset it every few tanks. And ignore results until you've put on 200km+.
Nitto Motivos, have 3k miles on them. 35PSI. Plugs have 45k on them, getting ready to replace those also. Oil change 2500 miles ago. I've had this tune for a while; this'll be my 3rd winter on it.
Originally Posted by G85 SS
You might want to get those fuel trims adjusted.
I'm astounded at people riding around with fuel trims that out of whack. And I'm shocked you're not throwing a "too rich at idle" code... Assuming you don't have a CEL or if you do don't even bother to check it.
By the way, I wouldn't rely on your interceptor gauge alone for that. If you are tuned you need to be logging the car and going back to review your logs. You will be absolutely amazed at the nonsense you miss just by trusting an interceptor. Because let's face it, when you are WOT or in heavy traffic, you're not putting your eyes on that gauge long enough to retain any valuable amount of information. There's going to be a ton of peaks and valleys where your trims probably spike into the double digits or just plain zero out on you under certain driving conditions.
The cheap tuners way to fix things like this is "let's just command more fuel here and take fuel out there in this table".
Come on kids!
I'll try and do some logging and see what I can see.
Last edited by Speed_Thrills; Dec 22, 2014 at 02:45 PM. Reason: Automerged Doublepost
Old Dec 22, 2014 | 03:15 PM
tomj77's Avatar
Originally Posted by Speed_Thrills
Like I said, LTFT used to be in the 7-9 range, and now all of a sudden, it's much lower.
Someone said LTFT was based on the downstream O2.. any truth to that?
As soon as I get my truck back from the shop, I'm going to replace the upstream O2 anyway..
Ltft in the 7-9 range? U need to get off that trifecta tune lol should be around 0
Old Dec 22, 2014 | 03:19 PM
It was like that for some time... Now it's down into the -3ish range, which obviously is a big change.
Old Dec 22, 2014 | 03:27 PM
umrdyldo's Avatar
I would think your fuel trims should get higher in winter.
Difference between 70 degrees and 35 degrees is roughly 5% higher trims.
Old Dec 22, 2014 | 03:44 PM
Shanedude's Avatar
Oh I was under assumption OP was Hptuned by ZZP not trifecta?
Old Dec 22, 2014 | 03:45 PM
I am HP Tuned by ZZP - I think Tom was referring to Vince's famously 'very rich' tunes.
Old Dec 22, 2014 | 10:44 PM
tuned08ss's Avatar
My ltft is still at -10.1
Old Dec 22, 2014 | 10:57 PM
Look at your intake valves. I'm betting your valves are pretty coked. Pull the brake booster nipple and use a bore scope to look at #3
Also where in MI are you?
Old Dec 23, 2014 | 02:48 AM
andrewcarr1993's Avatar
How many tanks of gas are we talking? One bad tank possibly? Secondly I believe winter gas if for all of the US not just part of it, which plays another big factor.
Forgot about the valves, check that first, a very common issue that's not all that hard to fix.
Old Dec 23, 2014 | 07:58 AM
  #36
South Eastern MI.
I didn't think of that.. Though I'm not sure it would cause such an abrupt change. I'm getting ready to do 80k maintenance so I'll be sure to make that part of it.
Old Dec 23, 2014 | 08:00 AM
  #37
I'm talking 2 months worth of tanks, probably 9-10ish. I'm leaning toward O2, like I said, but I'm sure winter gas isn't helping.. I know my car and how it acts in the winter (3 previous winters anyway) and this is uncharacteristic.
Old Dec 23, 2014 | 04:51 PM
  #38
South Eastern MI.
Def should check that out. I'm in hillsdale for the time being, if you where close and didnt know where I was talking I could of meet up and showed you
Old Dec 23, 2014 | 05:17 PM
  #39
umrdyldo's Avatar
If your valves were really coked up you would be feeling misfires during cold start most likely. Especially on a really cold day.
Old Dec 23, 2014 | 05:29 PM
  #40
tomj77's Avatar
I assumed trifecta cause those are the trims I saw on trifecta tune
Old Dec 23, 2014 | 05:32 PM
  #41
OP is zzp hptuned
Old Dec 25, 2014 | 01:11 PM
  #42
OP is zzp hptuned
Yes, am ZZP tuned.
Old Feb 9, 2015 | 02:47 PM
  #43
Bumping - new discovery. Vacuum at idle is -15.5. Used to be 19 if I'm not mistaken. Also, can't make more than 22PSI. Going to investigate for a boost leak.
Old Feb 9, 2015 | 03:18 PM
  #44
exninja's Avatar
Yeah should be around 19inHg vac at idle. If the AC is on then it'll come up to 17 or so. FYI, your idle vac numbers shouldn't be directly affected by anything upstream of the throttle body (eg boost leak), if that helps your diagnosis. Things upstream could indirectly affect it tho.
Old Feb 9, 2015 | 03:39 PM
  #45
I have a couple places I'm going to check for a vacuum leak, and if I can't find anything, I'll move on to other components. I'm doing some reading on here to see what else I can come up with.,
Old Feb 9, 2015 | 04:29 PM
  #46
Shanedude's Avatar
tomjj has to stop assuming so much especially when you're a super mod. Gives members a bad vibe.
Old Feb 9, 2015 | 05:03 PM
  #47
tomj77's Avatar
Originally Posted by umrdyldo
I believe your trims need to hit + or - 15% to throw a code.
Code pops at -18stft
Old Feb 11, 2015 | 06:14 PM
  #48
chris88z24's Avatar
Please tell me you're not resetting the DIC at 72 mph and going "omg, my gas mileage is so bad!"
Do it the right way and fill your tank to full. Record odometer at this time. Drive and then fill to full again. Note odometer again. Divide miles driven by gallons filled. There's your mileage.
Only way to do it. My LSJ gets 30 on the "highway", exactly what the window sticker says. Driving on county roads gets between 22 and 25, again what the window sticker says. The dash computer can be off by 2-3 mpg, sometimes more.
Old Feb 12, 2015 | 04:22 PM
  #49
tomj77's Avatar
What does being a mod have to do with assuming? So I assumed, sue me. It was a good assumption even if it was wrong. But I shall do my best to not assume anymore
Old Feb 12, 2015 | 04:23 PM
  #50
tomj77's Avatar
I did this a few time past few months, got about 29 in colder weather and 32 in fall weather. That's canadian mpg.
