Pothole+ H/E+Radiator=Leak.......
Old Apr 14, 2009 | 09:16 PM
19transam81's Avatar
I hit a pothole today which pushed my H/E into the radiator support on the drivers side. The support broke on the bottom driver-side. The leak is huge and it is coming from the bottom of the radiator on the driver-side right where the support should be. Well, the hole in the radiator is a perfect rectangle. Do you guys no if it is a possible drain plug that i took out? Or maybe the radiator support goes in there sum how?
bump anybody?
Last edited by 19transam81; Apr 14, 2009 at 09:17 PM. Reason: Automerged Doublepost
Old Apr 14, 2009 | 09:18 PM
ssyellow's Avatar
bump....damn you michigan and your pot holes!
Old Apr 14, 2009 | 09:19 PM
Jn2's Avatar
Jn2
there is no drian plug on our radiator, only 2 support tabs that hold it on the bottom left anf right, u most liely broke the radiator, either a gash crack and or hole on it now
Old Apr 14, 2009 | 09:31 PM
damn... well, i didn't even see it then BAM! I was not hapy thats for sure.
