problem with GM exhaust
Old Apr 23, 2008 | 10:31 PM
04redline0124's Avatar
It was awesome the first few days...but i now have an exhaust leak but have no clue where its from, its definately louder and doesnt sound like everyone elses with this same exhaust.
my question is, do any of you guys have a problem with one of the muffler from the exhaust? and if so how can i check it to see if thats the problem??
my mods are catless dp and the gmpp performance cat-back
thanks, any help would be appreciated
Chris
Old Apr 23, 2008 | 10:41 PM
stealthy1ss's Avatar
I doubt that the muffler is bad. I will put money on it being a loose connection or a bad gasket or imporperly installed gasket. Get under your car and try tighting up the bolts cause that is more than likely your problem.
Old Apr 23, 2008 | 10:42 PM
chad463's Avatar
Yeah check the connections. I had a bad connection between by downpipe and the rest of the exhaust.
Old Apr 25, 2008 | 07:59 PM
YSUsteven's Avatar
Check the flex pipe. It is the only part of the exhaust that is not rigid.
Old Apr 25, 2008 | 08:38 PM
If his downpipe is stock then he doesn't have a flex pipe.
Old Apr 25, 2008 | 08:40 PM
CobaltVenomSS's Avatar
yea he does...my flex pipe cracked a while ago....
Old Apr 25, 2008 | 08:42 PM
GULLABLE0NE's Avatar
if you had ashop put it on then have them check it out. more than likely a loose connection like stealthy said
Old Apr 25, 2008 | 08:45 PM
My bad. I just went and looked at my stock dp and the flex pipe is small and definately not the issue in this situation. If it was broke the OP would have complained about the car being really loud.
Old Apr 25, 2008 | 08:48 PM
thats my flex pipe cracked....LAWNMOWER!!!!!!!!
Old Apr 26, 2008 | 03:52 PM
its not quite that loud lol...but its close...ill check the connections it sounds like its comming out the side of the car lol
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
