Problem with POWER STEERING on DIC!!
When i got out of work today I started my car up. And sat for like 15 mins. When i got back it was warmed up. So i started driving home. I went on a run to the store. When i got back i started the car up and on the DIC i saw a message saying POWER STEERING. So im like WTF. so i turn the car off thinking that maybe it just failed this once. well i took the key out of the ignition and the car did not go off at all. it stayed on for about 45 secs. I was really confused. Has anyone else had this Problem..
Silver cobalt 2.4 SS sedan
I just had a problem with my power steering on my 05 coupe and it turned out to be nothing more than a bad wire. Hopefully it doesn't happen again. Just thought I would inform anyone with the same problem
Originally Posted by groucho
Talk to your dealer about your problem, it could be serious. The steering system is electronic, so if it ***** up, you could get seriously injured in a crash. Do it now!
Originally Posted by designt1
how would that be dangerous??? you'd still be able to steer the car.
Scott
I've had a similar problem, althought my DIC never came on. But I knowtice that when the car has been moving for a while and I've driven for about 30 mins if I turn the wheel around a corner it makes a growning sound and the faster I turn, the louder it is.
Wow,
Does the Cobalt have a PS Cooler pipe?
Originally Posted by Brian MP5T
Wow,
If thats your question, than no, I don't think it does. Reason being that electric motors don't heat up the way a hydraulic system would.
Originally Posted by wesmanw02
Do you mean like a Power Steering Cooling system?? Like the Corvette has??
If thats your question, than no, I don't think it does. Reason being that electric motors don't heat up the way a hydraulic systems would.
Sitting for a long time could cause it to heat up perhaps...
Cool, Just because on my Protege before I took the PS and AC off, the return line did a loop around to cool the fluid off. Thought that this could have the same thing possibly.
If the DIC displayed a "STEERING" message, there will be a DTC stored.
Originally Posted by NJBLUESS
BrinMP5T, the power steering systems on Cobalts are Elecrtonic. No fluid involved. The system uses what looks like a starter motor to assist in turning.
