Problems with my 07 SS/SC transmission! SH!T THIS!
Problems with my 07 SS/SC transmission! **** THIS!
So I only have GMPP mods: Rotors, Manifold, STG 2, Touring catback. A few other little things here and there, but mostly factory mods. I have the solid polyurethane mounts in, but I'm taking them out tomorrow. The vibes are really annoying with the A/C on, even just sitting at idle.
So my transmission is noisy. Everything about it. Clutch engagement is clicky, disengagement is clicky, going into 1st gear is an audible click outside the car, and I can hear the synchros grabbing (sounds like a progressive whine) in each freaking gear. Also, when I coast with clutch in but in 1st gear, it also whines right below the point of sounding like its grinding.
When I coast from about 40 to 0 in neutral I can hear something also mechanically whining in the front all the way to a stop. I think it's the wheel bearings because I do a ton of highway driving, but that's just me.
All in all, the transmission is noisy. I hear everything that goes on up front, and it gets me really worry because I.....HATE......DEALERSHIPS....WITH....A.....PASSI ON. and the last thing I want is to bring my baby in only to have the dealership tell me that I voided my warranty because I put GM parts and a DC strut bar on. I also switched to royal purple 75W90 to see if it would help, But what does everyone think? Am I on the brink of transmission failure? And does anyone have experience with Davidson Chevrolet in Watertown, NY?
let me just reiterate. This car is my baby. I take amazing care of it, document everything down to part replacement, oil changes, and I talk to it. Some say I'm crazy. Some just don't know about the fun of a SS/SC.
they cant deny you warrenty unless the aftermarket part without a doubt caused the failure. now nothing you listed would affect your transmission.
that being said, i have driven a couple cobalts and i find they are kind of noisy. you will always hear a click kind of noise going into first or reverse, any tranny will do that. i do find the stock tires a little noisy, and i thought it was a wheel bearing, however when i put my BFG kdw2 on the noise got louder imediatly, meaning it was just a tire noise i was hearing, and it actualy goes away with my winter tires on. i also have the clicky sort of noise on and off the clutch, however i only hear it if im listening for it and am in an area the sound bounces off (in traffic, beside a retainer wall, in a garage).
that being said, it is the cheap low end car thing (face it, thats what we own), however if it concerns you, and it sounds like it is, take it to the dealer and go for a road test with one of their techs.
im actually in the process of sue'in the dealer that denied my warranty coverage for the transmission on the cobalt...all they kept tellin me its from excesive wheel hop and they couldnt prove it..no snapped mounts,no burn rubber marks,no snapped axels,so obviously no proof,so i contacted my lawyer and case is almost done..
my transmission makes a clunk when I let out the clutch and it engages. It started once I put my solid trans mounts in. I'm also getting a wobble in 1st and 2nd gear, I just had my tires balanced so i know its not them.
LOL. Isn't that the truth. After taking my car in 5 times for that damn sunroof button they FINALLY totally replaced everything and put a little bracket in for me so it would stop falling off. Never had a problem with it since.
mine has fallen off for the second time yesterday
How many mounts did you replace with the solid urethane? I only had the front & back ones done for a while, and finally decided to do the driver's side one under the fuse box, and that made a WORLD of difference. Before, the vibes were really bad in low first and reverse. Now, they are barely noticeable compared to stock, and zero wheel hop. It is amazing. I guess the system just needed to be balanced. For anyone who has only filled the two mounts that most vendors have replacements for, I highly recommend doing the third one yourself. It takes some more time to get to it, but it is totally worth it. Not bad for $8 and a couple hours of my weekend.
Why do none of the vendors make a mount for this location? I don't get it. Think about it like a tripod--if you have only two sturdy legs and one weak one, the whole thing is unbalanced. And if it doesn't exist, I'd hate to find out what I filled with polyurethane then.
Well somebody needs to get the word out because it sure makes this car a lot more fun to drive. And it's also the piece of mind that the next time you ****-can it your not gonna snap an axle or crack your tranny case.
I can't stress enough how much of a difference it made over just having the other two mounts. It might take twice the amount of time to get to as the other mounts, but the results are well worth it IMO. I would say the vibes are about 30-40% of what they were before replacing the last mount. Good luck.
https://www.cobaltss.net/forums/private.php
There's a thread showing basically how to get to the mount. It's a tight squeeze, but definitely doable.
SOOOO ture man!! Well it makes me feel better to know that we're pretty much all in the same boat when it comes to these problems.....THey bothered me becuase i wasn't sure if it was just my car but this comfirms that i;m not the only one... thanx for that
