problems with my 2.2 lt
Old Oct 6, 2007 | 03:38 PM
420cobalt's Avatar
well to get to the point i start my balt in the morning and i get all sorts of cels. also runs strange wants to die when i stop, wont shift right, low fuel light comes on when i got a 1/4 tank, tc turns off and no power steering. this all started this week iv had this car for a year and have 20k miles. i didn't list everything but maybe u all have an idea what it is. i think the computer is done for. please let me know.
Old Oct 6, 2007 | 04:00 PM
NJHK's Avatar
Sounds like your computer is freaking out...
Take it to your dealership, have them look at it and they'll scan it to see in total all the codes coming up.
Old Oct 6, 2007 | 04:03 PM
420cobalt's Avatar
today was the third time this week that i have taken it in. they cant figure it out as of yet.
Old Oct 6, 2007 | 04:04 PM
NJHK's Avatar
Sounds like lemon law time!
How long have you owned the car?
Old Oct 6, 2007 | 04:07 PM
DebadgedBALT77's Avatar
i dont think youd have much luck with that. Throwing a tech 2 at it wont help as much as you think it would. It almost sounds like your BCM is taking a **** on you. Sounds like a bad electrical connetion somewhere in the circuit.
Old Oct 6, 2007 | 04:14 PM
420cobalt's Avatar
ive owned it for a year and put on 20k miles. my bro has the same kind of balt with no problems. i hope they figure it out but bad electrical connection sounds logical.
Old Oct 6, 2007 | 04:22 PM
joeworkstoohard's Avatar
yeah, his ground cable could also be loose, could be a lot of things, basically, i'd take it to the dealer and be like "look sport, fix it, and i want a loaner in the interum, because this is neither safe, nor reliable"
and if that doesn't work, have adam come over there and buttsecks them until they give in.
Old Oct 6, 2007 | 04:23 PM
NJHK's Avatar
http://www.yourlemonlawrights.com/state_laws/nevada.htm
Old Oct 6, 2007 | 04:34 PM
Im not sure what to say now. I got to thinking in our coblats, everything runs out of the BCM. including PCM. So i dont know as though that coud be the problem, or else nothing in the ar would work at all. Very dangerous thing to have on the back of you mind when driving. " Hmm wonder if my car is gonna compleyley shut off while Im going through town?" Lemon law is a possibility. But have them chek grounds and the like. Its warrenty work, so have them start hanging parts.
Old Oct 6, 2007 | 04:50 PM
420cobalt's Avatar
thx u all. the warranty has a long time to go. i need this piece of **** for work. i wish i got an ss/sc but too late. i will get it fixed or replaced ether way.
Old Oct 6, 2007 | 05:04 PM
NJHK's Avatar
Good luck
Old Oct 17, 2007 | 07:45 PM
420cobalt's Avatar
i don't think they have a clue whats going on. pissing me off. my car has been in the dealership for 2 weeks now. they say its my amp that i had put in there but ive had that in there for 9 months. does this sound right to any of u?
Old Oct 17, 2007 | 07:49 PM
BlackLsCoupe's Avatar
mine did sort of the same thing when i put my system in the trunk the positive battery conection was lose i guess just enough for it to have a bad conection. not saying it is the samething.
Old Oct 20, 2007 | 11:30 AM
420cobalt's Avatar
they were saying i can't have it in there because it disrupts the computer. i don't believe this to be true i think they just want to blame it on something i did. like i said ive had it in there for 9 months. wouldn't it happen as soon as the amp was installed ?
Old Oct 20, 2007 | 09:23 PM
posibly yea. ur amp could draw enough power to maby short out the computer. which i think is highly imposible.
Old Oct 21, 2007 | 12:47 AM
hobbie2k's Avatar
I just today got a CEL and lost my tach, '07 LS with 9800 mi. I'm hoping it's not as bad as yours. Good luck.
Old Oct 21, 2007 | 08:09 AM
Coblasts's Avatar
Check all your fuses in the fuse box under the hood,but mainly the ECW/trans fuse,This fuse seems to power everything that you are having problems with.It wont be blown but inspect the legs to see if there is any discoloration in the legs indicating a bad connection and reseat it properly.Then take a look at the big connectors on the fuse box.
Just thought of something else the crank relay I heard can come loose from wheel hop or just hitting bumps check it to.
Bad connections are a mechanics nightmare,things still work but the voltage drop they create cause havoc with the electrical system.
Did you Work on anything this week ?
Stereo car alarm etc ?
Old Oct 22, 2007 | 01:26 PM
420cobalt's Avatar
i will take a look at the fuses. i just got my **** back and so far its ok for the most part. i stoped in to a gas station and i started the car back up and traction control was off. hadn't had any thing els yet but if more pop up i got some ass chewn to do. they disconnected my amp and said problem solved.
i haven't messed with the amp in 6 months and no need for car alarm just use the stock.
Old Oct 23, 2007 | 01:41 AM
420cobalt's Avatar
hooked up the amp and still no problems. i think they are embarrassed to tell me the truth.
Old Oct 24, 2007 | 08:45 PM
420cobalt's Avatar
fix 1 thing and another problem pops up. fuel pump was leaking to day had to take it in for that now. what a pain in the ass.
Old Oct 25, 2007 | 06:13 PM
what and how many miles are on this? sound like a fucked up cobalt from the factory
Old Oct 26, 2007 | 12:50 PM
420cobalt's Avatar
i got a little over 20k miles on it. i think the computer was shittin on me because the positive battery terminal was loose and i doubt the dealership checked that. they just blamed it on after market wiring
Old Nov 1, 2007 | 03:23 PM
420cobalt's Avatar
the problems came back. im about to claim lemon. 4 times now its been in the shop for the same thing. really pissing me off!
Old Nov 1, 2007 | 06:05 PM
i bet it is with only 20k miles realy is starting to make me think GM should buy back ur ride. if its haveing nothing but problems. i got 42k on mine and ive had a system wired up since um 15k have had no problems after i fixed the loose positive.
GL with it
Old Nov 1, 2007 | 06:52 PM
YellowLT's Avatar
When my power steering kept cutting out, it was a bad ground wire.
