Pulse In The Break Pedel
i have an 07 Lt what does it mean if im getting a pules in the the break pedal but noT it the steering wheel, ive replaced front rotors and pads and had the new rotors cut because i was getting a pulse in the wheel also after the replacement, now the steering wheel pulse is gone but the break pedal is still there, it starts when breaking around 60-70 and it starts in the pedel and moves to the whole car vibreating, WHAT IS CAUSING THIS
Check the rear brakes as well, I have seen drums go out of round. Not common but......
Ya, what he said ^^^
the rears wouldnt be felt in the pedal just in the seat or sometimes the ebrake handle when u pull it up lightly while driving sounds to me like you got **** rotors and or someone keeps overtorquing you lug nuts after the do the job
The e-brake idea is not bad though, give a little pull while at highway speeds, not enough to lock the brakes but enough so you feel the brakes dragging and if you feel the same thing, it's the rear brakes for sure.
Don't forget to hold the button in unless you feel like doing 360's down the road
Overtorquing or improper torquing pattern could be an issue too.
i do have rear drums and i can feel it in the seat too, also in the ebreakhandle if i pull it while driving, if the drums are out of round do i just need to have them turned
Last edited by RecklessL61; Mar 26, 2009 at 07:46 PM. Reason: i used the wrong word
Why not? If the drums are out of round they will pulsate the shoes/cylinders/brake fluid in the lines, and eventually, the pedal.
So you have rear rotors and drums?? I dont get it? Our e-brakes use the discs there is no drum portion, either way the rotors warped, see if you can get it machined or if not them replace them.
Exactly, beat me to that. Easy way to diagnose which brakes are out of round/warped. Shake in steering wheel =front, shake in pedal =rear.
You know the drums do warp also, they get out of round and you get the pulsating petal
sorry should have read all the posts jumped the gun
Last edited by boostedss26; Mar 26, 2009 at 07:58 PM. Reason: Automerged Doublepost
i like how people say the rears cause pedal pulsation when i do this all day and am CERTIFIED to perform work. THe op did what i said he can feel it in the ebrake handle his drums are warped/ end thread and yes OP you can have them machined if the spec is above what it needs to be if not ull need to replace them. The reason you fell the padal and steering wheel in the front is beacuse the column connects to the rack which is attatched to the crade the from the axles through the hub and the rotors YOU WILL NOT FEEL PULSATION IN THE PEDAL FROM REAR BRAKES
[QUOTE=zrated89;3657714]i like how people say the rears cause pedal pulsation when i do this all day and am CERTIFIED to perform work. THe op did what i said he can feel it in the ebrake handle his drums are warped/ end thread and yes OP you can have them machined if the spec is above what it needs to be if not ull need to replace them. The reason you fell the padal and steering wheel in the front is beacuse the column connects to the rack which is attatched to the crade the from the axles through the hub and the rotors YOU WILL NOT FEEL PULSATION IN THE PEDAL FROM REAR BRAKES[/QUOT
CERTIFIED don't mean **** i know alot of people that are certified and are retards. My personal vehicles have had pulsation in the petal after i have done the fronts. Put shoes and drums on and hey no more pulsation. So don't come in here actin like you know everything. And the ebrake thing doesnt always work either
[QUOTE=boostedss26;3659099]
ok bodyshop man i do this everyday go beat some sheet metal
Hydraulics 101
Brake fluid is, for all practical purposes, not compressable. You will get feedback from the rear drums through the pedal.
And boosted is quite right....certified seems to mean nothing anymore. You have no idea how many certified technicians I have encountered in 30+ years that cannot understand how the systems they are working on interact, and it's getting worse every year. They cannot troubleshoot anymore, they swap out whatever part the diagnostic computer tells them to. It's really sad that dealerships (here anyways) get away with charging $99.00 an hour to have the tech swap parts until the problem goes away
I get far better work from the guy next store who learned how to fix things without a computer directing his every move. He learned by doing, not reading a manufacturers canned training materials and writing a cursory multiple choice exam. He understands how **** works, something I can't say about very many today.
Hydraulics 101
My wifes Taurus, on the other hand, actually had a hairline crack in one of the rear drums. Couldn't really feel it but you could hear it. Had a few people scratching their heads over that one. Figured it out when the guy who was helping me knocked the one drum on the floor to get the dust out, and it split in two!
Pretty much grew up with a wrench in my hand as well. Bought cars I could afford (can you say beaters?), couldn't afford to have someone else fix em when they broke so my choices were learn to do it or walk. I'm kinda lazy so walking didn't seem like such a great idea
Damn I miss my old beasties, big American iron that you could actually work on. Tuning with jets and metering rods, not a laptop. Want more static timing, twist the distributor. Being able to reach everything under the hood without having 3 elbows and twig arms.
Turbo Johnny
Feb 21, 2019 09:41 AM
Getaway_Driver
13
Aug 30, 2015 02:44 PM
