Quick problem with keypad and settings!
Old Jul 24, 2009 | 10:43 PM
bradk_1749's Avatar
Hello! I'll keep this quick and simple.
When I use my keypad to unlock the doors and stuff it no longer works. The dealer said to replace to batteries but it is unecessarily expensive to have them do it. I found out the code for the battery and picked up new batteries and replaced them. However the keypad is still not working. The dealer said I need to come in and have it reset, does anyone know how to set it up so my keypad work with my 07' Cobalt? Thanks so much everyone!
Old Jul 25, 2009 | 12:23 PM
CleverOne's Avatar
are you talking about the keyfob?
You may want to open it up and make sure the battery contact has not come unsoldered from the pcb, i had to open mine up and resolder the connection to the board.
Old Jul 25, 2009 | 12:45 PM
blackbolt89's Avatar
i've heard about problems like that. GM did some shitty soldering and apparently if you drop the fob like once you snap the solder.
but i wouldn't know from experience as i don't have power locks. :P
Old Jul 25, 2009 | 08:25 PM
bradk_1749's Avatar
"are you talking about the keyfob?"
Yes I am talking about the Keychain piece that has options like "unlock/lock/panic/trunk"
I dropped it recently and come to think of it I don't think it has worked since then. I will open it up and take a look how at the soldering. If it is indeed broken, how hard is it to fix (I am not familiar with soldering). Thanks for the quick responses everyone!
Old Jul 25, 2009 | 08:32 PM
CobaltSS 16's Avatar
how much is it to have them replace the battery in the key fob? One of mine is dying.
Old Jul 25, 2009 | 09:21 PM
Coblasts's Avatar
If your out of warranty you can resolder the battery holder yourself .
It doesnt need to be reprogrammed.
What it is like the other guy said ,the solder joint or connection is bad for the part the battery its in .
Take a close look at it and you will see the problem.
If you cant do it a guy at radio shack should be able to do it for a few bucks ,cheaper than buying a new one.
dennis69
Oct 20, 2015 07:39 AM
OrangeCoba
Oct 1, 2015 10:00 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
