a quick question
Old Jun 10, 2008 | 03:48 AM
PinaSS's Avatar
a quick question
well it has been over 4k miles after my last oil change during my oil life I have installed my s2 which gives excellent performance. In the last couple of days when I go WOT the s2 doesnt feel like when I first got it. Am assuming because of the oil. I need to change it out.
Am I right?
With a quick question as well. With mobil 1 how often do I have to change my oil 3k,4k,5k?
Old Jun 10, 2008 | 08:38 AM
RoAdsZ24's Avatar
i was told by the dealership that with the mobil 1 synthetic you can go until your oil life indicator goes down to 10%. I usually change mine around 20% and i have never seen power loss from bad oil.
fyi, the oil life indicator on your instrument panel does not actually test the oil. all it does is count engine rpms so if you drive at higher rpms for a longer time, the oil life will drop faster. i usually get about 4,500 miles between changes, which is just fine for synthetic oil under normal driving conditions.
Old Jun 10, 2008 | 08:50 AM
originaladrian's Avatar
could be a number of things, you should get your whole car serviced. changing your air filter makes a difference
Old Jun 10, 2008 | 09:19 AM
light'bolt's Avatar
Well being that your down there in laredo I figure its the heat more than anything els. Depending on what you want to do I'd open up the intake more, and look for a cobra heat exchanger to help a little with the cooling.
Changing the oil won't hurt either, check your plugs too and see how much carbon is built up on them.
Oh and slow down for awhile you may also just be getting used the driving fast all the time
Old Jun 10, 2008 | 09:21 AM
rrutter81's Avatar
or ur like everyone else and have gotten used to the power. mine wasnt as impressive after a month.
Old Jun 11, 2008 | 02:33 AM
PinaSS's Avatar
^yeah ur right but i dont really get on the gas that much. but am getting the raw intake soon so i should be getting a new filter.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
