quick question - lost interior 12v power
Old Aug 17, 2008 | 12:06 PM
X GEOFF X's Avatar
as the title states it looks like something is wrong with my cigarette lighter 12v outlets.. checked the fuse box but wasnt sure which fuse manages the interior outlets. what number fuse should i check. im assuming its a fuse problem but if thats not the case, any other ideas for why my outlets arent powered? thanks
Old Aug 17, 2008 | 12:21 PM
07touringcoupe's Avatar
Do you have the hand book? You should look in there and see what fuse it is!
Old Aug 17, 2008 | 12:25 PM
brett5's Avatar
FUSE! don't know which one but most like;y thats what it is...just check them and see which one is blown should't be hard there is a diagram on the back of the plastic you have to take off
Old Aug 17, 2008 | 12:37 PM
zay52790's Avatar
its the same fuse used for the trunk opener. Look at the diagram on the cover of the fuse box, its in there somewhere
Old Aug 17, 2008 | 12:39 PM
Chad92's Avatar
If you're looking at the fuse box under the hood, check the ACC/TRUNK fuse. I'm not sure which one under the dash if there is one under there that contributes.
Old Aug 17, 2008 | 12:55 PM
X GEOFF X's Avatar
hmm ok thanks for the help i knew there was a diagram but the way that the fuses are abbreviated i wasnt sure which one. but my trunk opens just fine, so maybe it's not the fuse? im at work right now but when i get a chance ill go take a look at the trunk/acc fuse and see what the deal is. thanks all for the advice.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Stuff
Oct 1, 2015 05:47 PM
