Red loctite on intake studs lsj.
Old Jan 7, 2016 | 08:58 PM
Bigslim's Avatar
Anyone have any tips on removing the intake studs? I recently did my stage 3 upgrade and I need to pull off my manifold to check my laminova cores o-rings. And am worried that I may have used to much red loctite when Re-installing the studs. People online say to heat it but how would you go about that with the manifold in the way?
Old Jan 7, 2016 | 11:30 PM
tomj77's Avatar
why would u use red lock tight? use blue if u ever want to remove them easily again. only thing I can think of is run ur motor to operating temp and then remove them, should cause the locktite to not hold as strongly.
Old Jan 8, 2016 | 04:45 AM
Bigslim's Avatar
All the instructions/ forums/ write ups I came across said to use the red loctite.... That's what I was thinking of doing. Just nervous of like warping manifold from going to hot then cold. Since it is like 30 degrees f here
Old Jan 9, 2016 | 09:56 PM
tomj77's Avatar
its colder than that here and iv never warped anything
Old Jan 11, 2016 | 07:45 PM
Bigslim's Avatar
Thanks, I appreciate that. That takes a load off.
Old Jan 14, 2016 | 08:35 PM
Bigslim's Avatar
Worked like a charm! Warm it up to operating temp, quickly disassemble belt, s/c then the studs on the manifold came right out! Thanks for them reassurance
Old Jan 16, 2016 | 10:24 PM
tomj77's Avatar
Haha ur welcome. I had an issue with I think it was a rusty exhaust nut once, did same thing and it came right off
06blackbalt
Jan 30, 2016 06:36 PM
QuickSilver_SS
Jan 28, 2016 02:45 PM
315SS
Jan 24, 2016 12:59 AM
Bigslim
Jan 7, 2016 08:10 PM
