Security light on
Old Dec 13, 2013 | 06:21 AM
MidnightTheSS's Avatar
Unhappy Security light on
Here's the thing I've done the relearn with the 3 cycle 30 minute process......okay this process I have done a total of 2 times yes the car started I drove it the entire day without it dying on me while driving.... so the third time I go outside to see if it would start security light comes on again I do the relearn again no luck battery dies
I get a jump security light comes on I do the relearn process (while still jumper cables are still hooked up giving extra charge it starts I let it run for 45 minutes to warm it up then shut it off had to work in the morning.I checked interior fuses they are all good only DTC I'm throwing is running too rich. I'm trying to figure out what's wrong with ut could it be the battery (by the way my key is bent a little bit almost where the plus sign is located don't know if that's the problem wireless tremor no longer works only have one set of keys that's how I got it from the car lot had the car for a year)
Old Dec 13, 2013 | 06:56 AM
blueLNFftw's Avatar
So basically the car isn't keeping the learning for the key?
Old Dec 13, 2013 | 07:43 AM
No it's not what could be the problem
Old Dec 13, 2013 | 08:22 AM
This sounds like the problem. There is a thread around here about what key to order off ebay so you can get a replacement cut and then relearn. Sometimes you have to take it to the dealer friend of mine's 06lsj the relearn on here didn't work, dealer charged like 50 or 75 I want to say for the relearn (some minimum bullshit it took like 5mins)
Old Dec 13, 2013 | 09:22 AM
I don't want to take it to the stealership all fuses are ok....the last time it was at the dealership was when I had the gmpp clutch kit installed after I got it from them I've had this problem
Old Dec 13, 2013 | 09:24 AM
I'm trying to get it started now so that I can take it to them if it's the BCM I can get it for $175 off rockauto I hope it's not that
Old Dec 13, 2013 | 06:56 PM
Well it's at it again looks like I'll be getting either the ignition switch or the BCM brand new spare and still locks me out F.T.P.O.S
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
