security light flashes once
Old Feb 24, 2015 | 01:36 AM
alexway12's Avatar
Need help I can't figure this out I've spent all day researching and have gotten no where my security yellow lock light flashes once and doesn't stay on and the car won't start ? I've tried the 3/10min key relearn procedure but the yellow pad light disappears ? Battery is good and so are the fuses
Old Feb 24, 2015 | 12:43 PM
exninja's Avatar
Did you do something between the last time it successfully started and now?
All of the warning lights should flash on momentarily before you try to start the car, so that light may not mean anything.
Old Feb 24, 2015 | 03:00 PM
CleverOne's Avatar
Double check the fuse block connections and the ECU connections, make sure the fuse block bolts turn until tight, if you hear poping noises while tightening keep going until irt wont turn anymore.
Old Feb 25, 2015 | 01:38 PM
05g5's Avatar
Try a different battery
My dad's had the same problem not 2 weeks ago
Old Feb 25, 2015 | 07:57 PM
alexway12's Avatar
yeah what happend was i was using that positive turmonal on the fuse box under the hood to jump the ac clutch to make sure it works , cause the ac wasnt working. but in the process of that i had the car on an had the ac @ full blast and soon as i touched the wire from the ac clutch to the positive turmonal it shut the car off and it happed i tried to start the car and i gues it threw it into this anti theft mode ? i tried using a different battery and checked all the fuses not one of them popped.
Old Feb 27, 2015 | 03:31 AM
alexway12's Avatar
Resolved the issue , had a dealer look at it today and come to find out that its a burnt bridge on the fuse box
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
