seized motor or supercharger? 2009 2.2 G5
Old 05-25-2017, 01:59 AM
Crav3's Avatar
Was driving today like normal, did a few highway pulls and car running fine. As i did a slow u turn i heard a loud clunk followed by something that sounded like air let out, like when you unplug the brake booster and it releases pressure. Now the car will not start, the starter tries to turn the motor but will not budge. I checked the motor oil and looks clean, no shiny flakes or missing oil.
i checked the air filter and belt to make sure they were good and the are. I cannot check the car until tomorrow when i get it towed home so i have to wait until i can take it apart and find out.
Only thing i can think of is the supercharger seized or the motor is seized. Has anyone ever had the supercharger seize up on them? What could cause it?
​​​​​​​btw the car is a 2009 2.2 G5, m62 supercharger with 2.9 pulley and 60lb injectors, with a dual pass and cai by AEM.
Old 05-25-2017, 02:05 AM
Sharkey's Avatar
never heard of one of these blowers seizing up.
Old 05-25-2017, 06:48 AM
This, and if a blower seized up the belt would slip before it would stop a starter. Pretty likely that you seized the motor.
Old 05-25-2017, 11:09 AM
user 72239's Avatar
pull spark plug. put long handled flathead down. try cranking. if it moves, hey its not seized. if it doesn't. RIP
Old 05-25-2017, 11:35 AM
Crav3's Avatar
Damn, not what i wanted to hear lol. Ill go pick it up later today, and will check it out. If anything i might be able to swap in a 2.4 now
​​​​​​​when i would crank it last night it would try to move and the pull back when i stopped. So im hoping its the supercharger so i can replace and sell it 😅
Old 05-25-2017, 12:51 PM
My buddy had a seized AC compressor and his car would not start becuase of the belt tension so it is technically possible
Old 05-25-2017, 01:20 PM
Crav3's Avatar
Went to try to start it without the supercharger and it started, the supercharger is seized. The pulley will not turn. Going later today to tow it home and start disassembling of the supercharger to see what went wrong. There looks to be oil by the supercharger plug on the snout. Wonering if somehow it leaked oil? I do wash the car regularly and never noticed the oil there. More info later tonigh.
​​​​​​​thanks for the help guys
Old 05-25-2017, 01:33 PM
user 72239's Avatar
damn that sucks. take it apart and post some pics
Old 05-25-2017, 04:34 PM
Interesting, I assumed the gearing ratio would be great enough to overcome the friction
Old 05-27-2017, 04:05 PM
tomj77's Avatar
Sucks but motor would suck more
Old 05-27-2017, 04:44 PM
We were pretty surprised too
Old 05-27-2017, 08:29 PM
Crav3's Avatar
luckily it was only the supercharger. So took it apart earlier today and i was hoping something was wrong with the snout, but it seems like a washer went into the supercharger. Really weird i know, really unexpected. There are no washers that i know of in the air intake or anyway for it to get in There. It really has me puzzled as i put the supercharger on and have not removed anything on the car for the last 4-5 months.
​​​​​​​i did take some pictures of the damage that i will post now.
​​​​​​​sorry could not get the pics posted, heres a link to the album though. Hope you all can see
http://s1177.photobucket.com/user/Va...arger%20broken
Old 05-27-2017, 09:22 PM
Damn
Old 05-28-2017, 01:56 PM
Crav3's Avatar
Does anyome think it will work if i just put it back together and try to run it like that? Or just change out the case since its crack and clean up the rotors where the washer got sruck. Would it work?
Old 05-28-2017, 05:35 PM
chevygirl2006's Avatar
I'd replace it
Old 05-28-2017, 08:08 PM
Sharkey's Avatar
the case is junk as it is, no point in putting the rotors in another case. just get a whole blower, they arent that expensive.
Old 05-28-2017, 08:10 PM
Henry3959's Avatar
I'd replace it
+1 But again I am very particular.
Old 05-28-2017, 08:54 PM
Crav3's Avatar
Ill probably have a friend check facebook as i cant find one on the forum and i messeged a guy that had one but got no reply.
​​​​​​​ Looks like the crack is just outside though, im taking it to get looked at by a friend at his machine shop. Ill see what he thinks, but still looking for a replacement
Old 05-28-2017, 10:45 PM
Henry3959's Avatar
These are too cheap used to even bother with that. It's worth whatever salvage aluminum is worth there. Your just lucky the rotors stopped the washer from going further or you could be looking at a new head or even a block.
Old 05-29-2017, 10:13 PM
Doug's Cobalt SS SC's Avatar
Wow bro this has me puzzled as well no idea how a washer could have gotten into your blower ? I've had mine apart a lot, I've replaced the needle bearings, snout bearings, put a new rotor pack in it & ive never seen a washer anywhere
Old 05-29-2017, 11:18 PM
Henry3959's Avatar
Not only have I not seen that size of washer anywhere in the intake system, how did it suck it into the SC.
Old 05-30-2017, 10:50 AM
jdbaugh1's Avatar
I've seen a seized alternator do the same thing on a Chevy truck. Was pulling on the belt so hard it caused the power steering pump bracket to flex.
Old 05-30-2017, 02:20 PM
Crav3's Avatar
Yea i did not see any washers like that anywhere near the intake manifold or brackets. I cleaned and made sure nothing was in the superchsrger or manifold before installing it. And that was about 5 months ago so it would have broke after sometime not 5 months later. It will remain an unsolved mystery lol.
​​​​​​​still looking for a supercharger, the one time i cannot find one lol
Old 05-30-2017, 02:31 PM
Henry3959's Avatar
What's your budget?
Search seller jreiland5 on eBay. Jerry has like 4 listed now.
Old 05-30-2017, 02:53 PM
Crav3's Avatar
Originally Posted by HGT
What's your budget?
​​​​​​​i was looking for something inexpensive. I dont plan on keeping the car, so just want to replace it and sell the car to get something else. Maybe somewhere around the $200 range. I sold my old supercharger for $180 and that one was very well taken care of.
